Hello everyone,
I remove flappers from subthrottle bodies and then on my dash appear F1 error code 62 and 32 I fix it and want to post here...
1. buy Capacitor 25v 500 microfarad, Resistor 8.2 Ohm 2 set.
2. Set this Resistor plus side on the actuator connector and than connect Capacitor (I had cut this connector and set there in line) (see pics)
3. take Subthrottle sensor and turn in 90 % not 100% and drill there and put some little pin and make stronger that not pull out.
4. :banana-metal: that's all it will disappear your Code 62 but, if not, disconnect battery 2 or 3 minute and then connect, if there will be again this code trust me that you have not move normally your subthrottle sensor in 90 %,
5. Ok let's make like this that was not any mistake, take tool and turn manually with your hand first 60 % turn on ingnation if code will be turn off ignation and than turn in 70 % and atc...(but don't forget that this capasitor and resistor must already installed in Valve actuator connector.) when you will see that was disappear, remember this turn % in sensor, drill and pull there some pin
Note: when you will turn off this bodies sensor and actuator must already removed flappers of course :thumbsup:
Have a nice day all !
Georgia, Tbilisi
Georgia, Tbilisi
