How to: Crankcase Vent Mod. - Page 11 - Kawasaki ZX-10R.net
 3Likes
post #101 of 143 Old 12-15-2014, 09:08 AM
theatiss's Avatar
5ponies??? Is that sure Shameless???
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #102 of 143 Old 12-15-2014, 12:59 PM
Balogiannis's Avatar
Send a message via MSN to Balogiannis
ΝΟ FUCKING WAY!
Balogiannis is offline
post #103 of 143 Old 12-16-2014, 04:26 AM
greenman43's Avatar
Images: 33
It does sound like a lot, but ... In around '87, Performance Bikes did a test using a GPX750 motor, and measuring the parasitic losses from various components. I'm far too lazy to try and find it, but if memory serves, the water pump sucked up about 3% of total power.
That said, it was over 25 years ago, and I'd imagine that water pump seal technology has moved on since then. Worth a try though, I reckon.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #104 of 143 Old 12-16-2014, 06:16 AM
Cheers,
Brian
In my opinion you will just ruin the water pump. If you want to do something just replace the mechanical water pump with an electric one and measure the gains.
I doubt you will see 5hp even with the stock water pump completely removed.
post #105 of 143 Old 12-16-2014, 07:52 AM
theatiss's Avatar
Cheers,
Brian
Parasitic losses like water pump, generator and ? ? ?
theatiss is offline
post #106 of 143 Old 12-16-2014, 05:21 PM
tyler.nd@hotmail.com's Avatar
But with electric water pump u will benefit from consistant temps and flow of coolant instead of stock goes faster as u go faster wen u realistically need most of the cooling wen your stoped at stop light or traffic.
tyler.nd@hotmail.com is offline
post #107 of 143 Old 12-16-2014, 06:09 PM
SkyDork's Avatar
Curious if you have a link to a decent Electric pump? I have an overheating issue on my ZX-7R and have married it down to the pump, radiator, or oil cooler. I wouldn't mind trying an Electric pump if they're reasonable.
#WordCrimes
SkyDork is offline
post #108 of 143 Old 12-16-2014, 06:29 PM
Get a chep heater pump from a big car,I got mine from an X5 BMW SUV for evaluation purposes.
Then if your problem is solved you can buy a pump with a controller and remove the thersmostat etc.
post #109 of 143 Old 12-16-2014, 06:50 PM
SkyDork's Avatar
I'll check into it. Thanks!
#WordCrimes
SkyDork is offline
post #110 of 143 Old 12-17-2014, 04:29 AM
greenman43's Avatar
Images: 33
Can't remember, I'm afraid. The guts of the article was looking at where power generated from the end went eg. if the fuel / air mixture created 105 hp, and if there was 75 at the wheel, where did the other 30 go ? Friction, heat loss through the exhaust, trnasmission losses, all that kind of stuff was covered.
Will see if I can find it sometime over Summer.
Cheers,
Brian
