How to: Block off plate alternative (Removing AIS) 3rd Gen - Kawasaki ZX-10R.net
post #1 of 50 Old 09-22-2009, 07:22 AM Thread Starter
TENN10's Avatar
Images: 145
Since it will not quit raining here, I was forced to do a few modifications instead of ride.
I was under the tank and in the airbox for a test mod. (coming soon) and snapped a couple of pics for a short visual "How to" (assuming you can lift your tank and remove the airbox cover on your own).
The first pic. is the original setup with the Air Switching Valve shown with a Red X.
The Red arrows are the hoses that connect the stock plates to the valve.
The Yellow arrow points out the two wire plug that will need to be undone.
The Red Circle is the vacuum line coming from the airbox that will need to be capped or plugged. This is where the Switching Valve pulls air from to be sent through the exhaust to help burn any unburnt fumes for emissions.
Second pic. is showing the hoses removed, airbox capped, and the 2 wire connector jumped (Thanks MagicMavis) to avoid getting an FI light fault. The Air Switching Valve is completely loose and can be removed.
Third pic. shows the modification complete (except for securing the jumper wire).
The hose connecting the stock plates is part of the original vacuum line that was connected to the airbox. Cut to length and secured with 5/8" hose clamps.
The airbox is capped using a plug I had laying around and some high temp. silicone to hold it in place. (I have since removed this cap and used a 5/8" cap and hose clamp)
Maybe this will help someone.
TENN10 is offline
post #2 of 50 Old 09-22-2009, 07:45 AM
rkwaki's Avatar
Fuggit - just put a marble in the vac hose that connects from the airbox to the AIS. I too lazy to do all that work.
Great write up though :)
You're right this rain is wearing me out - had hail this morning leaving home.
rkwaki is offline
post #3 of 50 Old 09-22-2009, 08:29 AM
morefire's Avatar
This mod stops the off throttle pop & backfires...which I think sound cool..... so Im not doing this mod
Waiting for the 2011 ZX10R
morefire is offline
post #4 of 50 Old 09-22-2009, 08:29 AM
TMAC's Avatar
Images: 86
What is the benefit of doing this?
Edit - answered as I posted.
2007 ZX-10R - 156 RWHP/182 MPH
2009 KX450F
2006 636 (Sold)
99 ZX-6R (Sold)
94 Ninja 250 (Sold)
99 YZ-250 (Sold)
73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htm
TMAC is offline
post #5 of 50 Old 09-22-2009, 08:56 AM
5-F Dawg's Avatar
great write up
BOOM!!! SHAKE AND BAKE
5-F Dawg is offline
post #6 of 50 Old 09-22-2009, 10:23 AM Thread Starter
TENN10's Avatar
Images: 145
Maybe you'll like the "crankcase vent mod." instead.
You can have your cake and eat it too.
TENN10 is offline
post #7 of 50 Old 09-22-2009, 11:20 AM
Nice - a cheaper alternative to the Graves block off plates. I discovered the simplicity of the system only AFTER purchasing the plates, so I threw'em on anyways. Points for being clever.
"Do not be overcome by evil, but overcome evil with good."
speedster_Chris is offline
post #8 of 50 Old 09-22-2009, 02:38 PM Thread Starter
TENN10's Avatar
Images: 145
I can't take credit for this one. Its just easier to do a picture How To, than
explain this mod. over and over.
Thanks for the MAP Recongnition in the sig to You and Morefire. I hope that your bikes run like mine.
TENN10 is offline
post #9 of 50 Old 12-12-2009, 12:10 PM
espen's Avatar
Originally Posted by TENN10 View Post
I believe this pic was one I posted earlier (without the X and the arrows).
If you look closely, the hose from the airbox is blocked, as is the outlet from the airbox (that blue hose with a black stip on it).
This is all you need to block the system. No need to remove the valve or replace any hoses.
espen is offline
post #10 of 50 Old 12-13-2009, 07:03 PM
B.K.'s Avatar
I never got a FI light when disconnecting mine (plug is just hanging there taped up), but I also have the kawi race ecm. Just curious if everyone with stock ecm's get the FI light?
Current Bikes
08 ZX10R Nassert-Beet Exhuast, BMC race A/F, Graves smog block off plates, Kawi race ECM
02 Cannondale E440 stock
93 CBR900RR Two-Bros Full exhaust, K&N, Dynojet kit
Past bikes
02 Honda RC51 Sato exhaust, PWC3
01 Honda RC51 Stock
73 Honda CB750 Megaphone exhaust
B.K. is offline
