HID Projector headlights - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 12 Old 11-22-2017, 12:04 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
All you have to do is find the low and the high beam feed wire going to each and tie it in to the factory Loom and you will still have high and low beam on the switch
hellsrazor is offline
post #12 of 12 Old 03-06-2018, 01:11 AM
songwriter's Avatar
this is a job..for real
I did this mod to my 16. This was a nightmare to say the least. I do not blame a shop for not wanting to do it. The main issue for me was find place to put all the boxes and wiring it takes to operate these. To be honest, most of mine is zip tied into every nook and cranny I could find. There is little room to put it on the front of the bike and the stock wires restrict you from under seat mounting ( not that there is any room there either). There is quiet a bit of hardware behind the fairings already. This is a real labor of love. I probably worked on mine like 40 hours. A lot of trail and error. There is a ground issue with trying to find something good to ground to. I wound up going all the way to the battery because of everything being aluminum. I am afraid to try to pull my fairings again lol , remembering how hard it was getting it all to fit. That is the bad... The good is .. these lights are super bright. I ride a lot back and forth to work in the dark and these are the best lights I have ever used. I have owned a few different bikes mainly different ninjas. ..Also these lights look bad ass in the new bikes... Lastly, this is my first post on here been reading it for a while , so Hello All. If you are down by the Tail of the Dragon give me a yell, its about 10 minutes from my house.
songwriter is offline
