Gen 5: 2016 -> Gen5 Stall problem help - Kawasaki ZX-10R.net
 3Likes
post #1 of 18 Old 05-20-2018, 06:37 PM Thread Starter
Steve White's Avatar
So I have an issue that when my bike is coming down in RPM it drops below the idle limit and the bike stalls. I've asked my mechanic and my dyno tuner guy and we're all pretty unsure. I have a BMC race air filter, Akrapovic mid pipe and slip on, and the ECU is flashed and tuned. The issue has been happening since before the ecu flash and tune so that isn't the problem. I don't remember exactly when it started though. Any suggestions?
https://youtu.be/AQPdxb0DuQA
Steve White is offline
post #2 of 18 Old 05-20-2018, 06:45 PM
The Pace
scout's Avatar
Have to find a Kawa tech guy. As you know, should've would've before you ran to the flash nonsense as then kawa tech would have one LESS intervening variable to sort out about a warranty go or no situation.
scout is offline
post #3 of 18 Old 05-20-2018, 07:35 PM
97grnrs's Avatar
Sometimes dirty throttle plates can cause that issue even oil buildup. Or flash the idle higher
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. http://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #4 of 18 Old 05-20-2018, 07:37 PM
SkyDork's Avatar
The simple fact that you're revving the living shit out of a cold motor in neutral makes me cringe. That poor motor. Stop doing that shit.
Some people have mentioned that issue before, but while they are actually riding it. It's related to the QS from their analysis. So without knowing who did your reflash, what settings they used, turn off the QS and ride the bike.
wheelz96 likes this.
#WordCrimes
SkyDork is online now
post #5 of 18 Old 05-20-2018, 07:59 PM Thread Starter
This has been happening for a while. I'll try turning off the QS tomorrow when I take the bike out. I know it's bad but I needed to demonstrate for the video. I had Nels from 2wheeldyno do the flash and tune.
post #6 of 18 Old 05-21-2018, 07:54 AM
SkyDork's Avatar
After turning off the QS function, let us know the results.
Nels does good work and the reflash is typically not an issue. But, something else may be going on and the settings used to adjust the QS may be contributing to your issue here. That's not always the case, but others have mentioned the it. Was the auto-blip enabled? Was the idle speed adjusted in the reflash? Does this problem happen in all gears or just one? What is the EBC setting you use?
#WordCrimes
post #7 of 18 Old 05-21-2018, 08:50 AM
Check all the sensor connections and air lines that are on the throttle bodys make sure nothing's pinching I had a similar problem and my map sensor not plug in all the way
Sent from my SM-N950U using Tapatalk
Ronaldlee505 is offline
post #8 of 18 Old 05-21-2018, 04:35 PM
skidooboy's Avatar
have nel's bump the idle and re-test. Ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #9 of 18 Old 05-21-2018, 09:38 PM
chiffeee's Avatar
throttle body balance, your mechanic, and tuner should know
chiffeee is offline
post #10 of 18 Old 05-22-2018, 12:14 AM Thread Starter
I turned off the QS and no change even at 190 degrees. Already had Nels bump idle to 1700. I'll speak to them about the throttle body things.
