Gen 5: 2016 -> Gen5 Stall problem help - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 18 Old 05-24-2018, 12:19 AM Thread Starter
Steve White's Avatar
So I went out for a ride today and I had another issue with the bike. My ESD warning light kept coming on. The bike didn't stall beforehand and I wasn't doing anything out of the ordinary. Could it be a Battery problem?
Steve White is offline
post #12 of 18 Old 05-28-2018, 04:52 PM
ddipaola's Avatar
My bike is doing the same thing. Clutch in, coming to a stop, and it stalls. Was able to replicate on a stand just like you.
I'm thinking about taking it to the dealer tomorrow to see what can be done. I recently had my bike custom tuned but I've had it flashed since last year without ever having an issue. So I'm almost tempted to rule out the flash kit. The ESD (from what I've read) is not relative to the cause of the stalling but is instead a result of it. When my bike stalls the ESD comes on after restarting (but not every time), but it will immediately go-away if I fully reset the bike (key-off, key-on). If you've got any update please update us (me lol).
When in doubt... send it!
ddipaola is offline
post #13 of 18 Old 05-28-2018, 05:48 PM
This happens on my bike as well. Stalled once on the grid before a race. Not the most comforting feeling. I have a kit ecu with a hand-me-down (for now) map. I thought it would be due to that but may be not? I've upped the idle a little and it helps but I think something is still isn't right. Subscribed!
ddipaola likes this.
Lanister is offline
post #14 of 18 Old 05-28-2018, 10:11 PM
ddipaola's Avatar
I just noticed this today, but when I rev'd my engine a certain way the RPMs not only hit zero, but the headlights dimmed, and the dashboard flickered. I didn't notice this before. And actually if you re-watch my video you can see that dash flicker. Says to me there's maybe an electrical problem related to the battery. I checked it with a multimeter and the voltage was perfect... perhaps a stator issue then? Need to look into it more but maybe your stalling is showing those same symptoms. I've got a Lithium battery coming in this week. I will keep the thread updated with any positive feedback.
ddipaola is offline
post #15 of 18 Old 05-31-2018, 11:21 PM
I have a lithium ion battery so it's not likely to make a difference.
Lanister is offline
post #16 of 18 Old 06-01-2018, 06:50 AM
Newf's Avatar
With the new 1.1 software if you run a low number in the engine brake map it tends to not want to idle after blipping the throttle, have tested it by switching engine brake maps and when I use the map with “8+” it would idle perfect. Have seen the issue on a bunch of bikes running the 1.1 software and they just increase the idle rpm to help also.
Newf is offline
post #17 of 18 Old 06-01-2018, 01:51 PM
ddipaola's Avatar
Yeah, I looked more into the electrical and the battery/stator/regulator were all running perfectly. For some odd reason the bike hasn't repeated the issue in a couple days. Maybe a hose was kinked or something, not sure. Also, zero tank pressure buildup which is good. Either way that lithium battery is going in for weight savings haha a free 4-5lbs worth of saving & the quick-disconnect feature for storage sounds like a good move.
ddipaola is offline
post #18 of 18 Old 06-15-2018, 12:07 PM
Mine was doing the same thing after remapping the ECU using woolich software (The Map). Changing my air filter, cleaning up the oil on the throttle, and fixing that seal on the airbox resolved the issue for me. I went from a M4 GP slip-on to a SC-Project CR-T slip-on.
chancity is offline
