Gen4 zx10r won't start with all dash lights blinking. - Kawasaki ZX-10R.net
 5Likes
post #1 of 21 Old 06-07-2017, 08:17 AM Thread Starter
Alex Kam's Avatar
Hi guys.
I really need someone to help me this. Currently my bike can't start and with all the dash lights blinking. It is really a weird problems.when I turn on the key my TC light blink and FI stay ON. Fan was turn on with cool engine. I call kawasaki service center and they told me they didn't meet this kind of problem at all. What a head now.
Alex Kam is offline
post #2 of 21 Old 06-07-2017, 09:26 AM
Duhastme's Avatar
Welcome to the forum!
First thing to do is pull the codes from the ECU, use the search bar and there are other threads instructing how to do this. Once you figure out what the codes are, use that fancy search bar again and find out what the codes are telling you. After all this report back and we may be able to help you further.
The more you learn, the more you realize how little you know.
Duhastme is offline
post #3 of 21 Old 06-07-2017, 09:38 AM Thread Starter
Alex Kam's Avatar
I did pull out the error codes. Funny is I got few error codes. 11,12,13,14,31,32,33,34.
Alex Kam is offline
post #4 of 21 Old 06-07-2017, 10:48 AM
Duhastme's Avatar
Did you look up what those all stand for? That would be your next step.
SkyDork likes this.
Duhastme is offline
post #5 of 21 Old 06-07-2017, 11:50 AM
SkyDork's Avatar
Welcome.
Since you're getting codes associated with the main throttle sensor, intake air pressure sensor, intake air temp sensor, water temp sensor, vehicle down sensor, subthrottle sensor, oxygen sensor, and butterfly valve sensor, I'm going to go out on a limb and tell you you have a problem.
Do you see the issue here? Anything catch your eye? Yeah, you've got a sensor issue - and by that I mean it's likely in the fact that the sensors are not communicating properly. First thing I'd be looking at is the CANbus wiring for communication link to all the crap on the bike. What have you done to the bike recently? What did you forget to plug back in?
SNSSTR likes this.
#WordCrimes
SkyDork is offline
post #6 of 21 Old 06-08-2017, 01:34 AM Thread Starter
Alex Kam's Avatar
Almost every stock. Recently just change a servo buddy due to servo spoiled. DIY servo eliminated.
Alex Kam is offline
post #7 of 21 Old 06-08-2017, 05:03 AM Thread Starter
Alex Kam's Avatar
Ok. Problem already found. My ecu was die.......anyone got ideal where to get a new or 2nd Ecu ?
Alex Kam is offline
post #8 of 21 Old 06-08-2017, 05:19 AM Thread Starter
Alex Kam's Avatar
My mechanic told me I can't put in a used ECU into my bike. Cos used ECU immobilizer already been set. It won't be able to set for another bike again. Is it true? Is there another way to reset the immobilizer?
Alex Kam is offline
post #9 of 21 Old 06-08-2017, 07:25 AM
SkyDork's Avatar
No, that's not true. The ECU and ignition keys have to be re-registered to each other to match. There's a whole procedure in the service manual about doing it. Same thing as registering a new key to your current ECU.
But how did the ECU "die" exactly? That's not normal or common at all. It suppose it can happen, but I'd be suspect about that.
#WordCrimes
SkyDork is offline
post #10 of 21 Old 06-08-2017, 07:27 AM Thread Starter
Alex Kam's Avatar
Suspect there are some wiring short circuit.
Alex Kam is offline
