Gen4 rece int cam on stock comp engine - Kawasaki ZX-10R.net
post #1 of 9 Old 10-13-2017, 01:15 PM Thread Starter
Hi.
I will do my 15k miles valve clearence ckeck soon and I have some questions.
1. Will I loose power if I put the race int camshaft on my stock comp motor?
2. Is it better to just degree the stock cams?
3. What's the (measured) truth stock ex camshaft lobe center 104 or 107.5?
4. Did anyone of you see gains from tuning each cylinder separately? ( mwr sbk filter and velocity stacks are on the way)
5. What's your cam degree numbers advice on either camshaft selection?
My bike is flashed dyno tuned with arrow full titanium exhaust and kN race filter.
300ZX10R is offline
post #2 of 9 Old 10-25-2017, 03:21 PM Thread Starter
Anyone?
300ZX10R is offline
post #3 of 9 Old 10-25-2017, 06:07 PM
GreenOne's Avatar
3. 107.5 by spec. see service manual snip below. Measured 100% accurate would be somewhat engine specific. (chain stretch, tolerances etc.)
4. Although a difference in fuel requirement is expected even for a inline 4, it`s not very common for the average joe to do this because of the effort and cost vs potential gains. Probably not many people with experience here.
I can only speculate on the others, so I won`t ;)
I`m just in for the ride
GreenOne is offline
post #4 of 9 Old 10-25-2017, 09:57 PM
gaz
google gen 4 zx10 cam timing, under zx10r.net there are measured and factual results that will answer ur questions. i have limited experience with these cams and degreeing them but with .45mm hg and head deck .015-.020. can easily lose more power than gained on stk motor.
gaz is offline
post #5 of 9 Old 10-26-2017, 01:40 PM Thread Starter
Gen4 race int cam on stock comp engine
All these questions came after reading all of these threads.
Didn't see anyone changing cam timing on stock motor.
I will see if there is any gain with velocity stacks and mwr sbk air filter.
Then while checking the valve clearance will check the stock cam timing.
My thoughts are to keep the stock cams and degree them to 110 108.
300ZX10R is offline
post #6 of 9 Old 10-26-2017, 02:50 PM
GreenOne's Avatar
From the spec i posted above you should expect to be at 112/107.5 stock. With 110/108 you might be going in the direction of less peak hp and shifting the powerband lower from lsa tightening and intake advance.
GreenOne is offline
post #7 of 9 Old 10-26-2017, 04:57 PM Thread Starter
According to race manual stock cam timing is 112 104 and at service manual is 112 107.5 that's why I asked what's the true (measured) cam timing in gen4.
300ZX10R is offline
post #8 of 9 Old 10-26-2017, 05:11 PM
GreenOne's Avatar
Yeah, would have helped if you mentioned that you asked because the manuals have conflicting info. Pointing towards error in the service manual. Have you seen this post?
Cam Timing
GreenOne is offline
post #9 of 9 Old 10-26-2017, 05:33 PM Thread Starter
Yes I have.
The only way is to measure it myself and see.
300ZX10R is offline
