Gen 5: 2016 -> Gen 5 Ignition timing - Page 3 - Kawasaki ZX-10R.net
 6Likes
post #21 of 29 Old 01-04-2018, 10:11 PM
Newf's Avatar
Originally Posted by Cabilloabajo View Post
+4-5??? Please elaborate a little bit more
Itís with the race ECU, so Iím not sure what the base ignition timing maps are but theyíve added upto 5 degrees of timing at 100% throttle high RPM and a little less midrange and part throttle.
race ecu base map vs ignition/fuel tuning on 95RON pump fuel.
Newf is offline
post #22 of 29 Old 01-05-2018, 12:47 AM
Victors's Avatar
Is it 4 to 5 through the whole rpm band?
2013 10R
2007 650R
2016 10R
Victors is offline
post #23 of 29 Old 01-05-2018, 07:02 AM
mpp12's Avatar
Interesting, my gen4 that puts 192hp, is indifferent to timing on top en 31-35 same hp. so I use 31...
gaz likes this.
mpp12 is offline
post #24 of 29 Old 01-05-2018, 08:34 PM
Newf's Avatar
Think itís about 8k upto 14k, doing some ontrack tuning this weekend so will have a closer look.. planning to try e85 also!!!
Newf is offline
post #25 of 29 Old 01-05-2018, 08:41 PM
Victors's Avatar
Interesting. Get back to me after you take a second look at it. Would love to see it.
2013 10R
2007 650R
2016 10R
Victors is offline
post #26 of 29 Old 01-06-2018, 09:57 AM
bun1t's Avatar
My Gen 4 picked up 7whp with pump E85 (it tested at a true 85%).
bun1t is offline
post #27 of 29 Old 01-06-2018, 05:06 PM
Newf's Avatar
The e85 here in Thailand is actually only around 70% ethanol, hopefully itíll still add some midrange atleast but still be able to make race distance from a full tank of fuel.
Newf is offline
post #28 of 29 Old 01-07-2018, 08:05 AM Thread Starter
Try using Sunoco 260 GT Plus or VP MR12
Cabilloabajo is offline
post #29 of 29 Old 01-07-2018, 08:54 AM
Newf's Avatar
Not much available here for racefuel other than whatís left over from WSBK weekend like panta 102 or elf & eni. Some guys use ETS buts the prices are crazy high like $300/50L
I run Panta 102 in the s1000rr but if the e85 does the trick itíll be a lot cheaper and easier to use.
Newf is offline
