Gen 2: 2006-2007 Gen 1&2 Electrical troubleshooting wisdoms - Page 3 - Kawasaki ZX-10R.net
 1Likes
post #21 of 24 Old 05-27-2015, 02:00 PM
NinjaLife's Avatar
Crap that OEM stator is almost double the cost of the Ricks stator! I have heard a story or two about Rick's stators dying prematurely too. I replaced mine with a ricks though and all has all been good. There's a few other members who have also used Rick's stators and haven't had any issues. I think Rick's will stand by their product though if it fails.
NinjaLife is offline
post #22 of 24 Old 05-30-2015, 08:35 AM
PigMan's Avatar
Well the old battery read 10.50 volts. Dead as dead can be. Installed the new one and it reads 12.28 then 12.44 @3000 rpm. Ok or think I should go after the stator?? any help would be appreciated..
PigMan is offline
post #23 of 24 Old 05-30-2015, 04:23 PM
PigMan's Avatar
Well this video confirmed my suspicion.. bad stator.. my bike is making the same noise.. :(
https://www.youtube.com/watch?v=ygihY76vs8E
So I went to the dealer to order a new one and yes I got one.. A new 2015 ZX10R AbS green and black ... :) Ill post pics when I pic here up..
PigMan is offline
post #24 of 24 Old 07-05-2015, 04:42 PM Thread Starter
The voltage needs to be higher. 12.44 is not enough to reliably start your bike, it needs to be 12.75 minimum. You probably have a problem with one of the legs on the stator.
The stator has three separate circuits in its copper coil windings. If one of the legs goes bad, then the stator is unable to produce the full 14.4 volts @ 3000 rpm. You can test this by using a multi-meter on the three wire plug for the stator. There should be continuity and less than 0.2 Ohms of resistance between each of the three wires and to frame / battery ground.
2006 ZX-10R :: Just a shade tree mechanic keeping a 75,000 mile beast alive.
antaren is offline
