Gen % GP Shift Pattern - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 9 Old 04-30-2018, 12:40 PM Thread Starter
kawboy69's Avatar
Gen 5 GP Shift Pattern Help
Can you reverse to GP shift pattern on the GEN 5?
Thanks in advance,
Don
It's better to shut up and appear stupid than open your mouth and remove all doubt.
kawboy69 is offline
post #2 of 9 Old 04-30-2018, 12:54 PM
SkyDork's Avatar
Yes! I run mine with the reverse pattern! Love it!
You need to do one of 2 things to make that happen - put the G3 throw-arm on the there and reflash the ECU. Or get a bellcrank adapter for the rearset. Both of those assume you wanna keep the QS on there.
PS - You need to let go of the shift button when pressing the #5 on the keyboard.
kawboy69 likes this.
#WordCrimes
SkyDork is offline
post #3 of 9 Old 04-30-2018, 07:10 PM Thread Starter
kawboy69's Avatar
Thanks SkyDork👍🏻
kawboy69 is offline
post #4 of 9 Old 04-30-2018, 07:33 PM
SkyDork's Avatar
If you haven't tried this yet, you'll find that the QS interferes with the frame if you keep it. There's ways around that, but flipping the linkage over won't make the QS work properly anyway. You can remove the QS and secure it out of the way to get it done. Otherwise you need to reverse it in the ECU software and space it with a new rod. Assuming of course, that you're trying to use the stock rearsets.
#WordCrimes
SkyDork is offline
post #5 of 9 Old 05-01-2018, 12:20 PM Thread Starter
kawboy69's Avatar
SkyDork do you have any pics of this or similar post showing examples?
kawboy69 is offline
post #6 of 9 Old 05-01-2018, 01:47 PM
SkyDork's Avatar
Which part exactly? I have pics of the setup from my Gen 4 with the G3 throw arm. It's basically the same for the G5 without the QS on there. Is that what you're looking for? Or are you wanting to keep the QS?
#WordCrimes
SkyDork is offline
post #7 of 9 Old 05-02-2018, 10:41 AM Thread Starter
kawboy69's Avatar
i am looking to keep the QS, but i had seen a post but cant find it now where someone reversed the QS switch.
kawboy69 is offline
post #8 of 9 Old 05-02-2018, 10:47 AM
SkyDork's Avatar
OK then. Give me a little while to dig up that post. From memory on that, the member used G4 Vortex rearsets, the G3 shift arm, had to match up the threaded rod, and space out the QS module slightly so it wouldn't contact the frame rail there. And as I said, if that's done, then the software in the ECU must be reflashed to allow it to work since it will be opposite in that configuration.
I'll do some snooping and post up a link shortly.
#WordCrimes
SkyDork is offline
post #9 of 9 Old 05-03-2018, 07:31 AM
SkyDork's Avatar
Check these links out for past threads on the topic.
GP Shift 2016 ZX10R: A Dirty Mod...
Just Picked up my New 2016 ZX10R ABS!!!
Best way to change to GP shift ?
#WordCrimes
SkyDork is offline
