Fan temperature kick on - Kawasaki ZX-10R.net
post #1 of 5 Old 12-15-2016, 09:10 PM Thread Starter
Did anybody know if they're a kind of electric gimmick who could be done to make the radiator fan kick on at a lower temperature on a gen 1 zx-10r ?
The thing are I do the THG modification with the cam timing appropriate and the second fan mode was done, sooo the only thing who can be change is to set the temperature at which the fan kick on and it's probably a kind of a signal who are coming from the temperature sensor who increase or decrease in voltage and at a certain voltage the nsignaal kick on the fan.
So if anybody do this mod or know how to do it without flash the ecu tlle me, I will save a lot of try and error this way.
Thanks and happy holliday.
ninja_12r2000 is offline
post #2 of 5 Old 12-16-2016, 04:29 AM
or10r's Avatar
You can do the manual fan switch mod shown here...
How To Install a Manual Fan Switch ZX10R 04/05
Its an easy solution and works well. I put my switch between the brake reservoir and triple tree. You can see it in red here. Its inconspicuous and easy to get to.
or10r is offline
post #3 of 5 Old 12-16-2016, 06:22 PM Thread Starter
Did anybody know if the voltage change with the increase of temperature from the sensor bolt on the cylinder block ?
post #4 of 5 Old 02-22-2017, 11:10 AM Thread Starter
Nobody resolve this funny thing about make the fan kick on at a lower temperature, even modify the signal to made it start earlier in temperature ?
Is there a way an electronic guru could know ?
post #5 of 5 Old 03-01-2017, 12:23 AM Thread Starter
Did the teperature sensor of a first gen (2004-05) can be change with a more recent model one ?
And did the kick on temperature of let say a second or third generation sensor start the fan at a lower temperature ?
