Exhaust Butterfly Valve Actuator Sensor - HELP!!! - Kawasaki ZX-10R.net
post #1 of 13 Old 03-09-2009, 04:41 AM Thread Starter
Big Head's Avatar
Images: 32
Hello guys,
at first Im sorry for my english. Im from Europe so please be patient...
Ive got problem with my ZX10R 2006. Ive got Akrapovic slip-on on it and everything was OK last year. The bike was kept in garage through the winter for more than four months. I started my bike last week and ooops... FI LED on my meter is still blinking!!! So I recalled the service code and code is 34! So there is some problem with Exhaust butterfly valve actuator sensor (Service manual pages 169 and 178). And my question is. Do I have to buy new one which is 170$ (please tell me its not necessary) or is there some cheaper solution for this problem? Few of my friends told me that I can only cut one wire and the problem is solved! If yes, what color the wire is?
Thank you...
Big Head is offline
post #2 of 13 Old 03-09-2009, 05:18 AM
thrill's Avatar
Valve in the exhaust could be seized up. See if you can rotate it by hand with the cables removed. If so check that the cables are free. If they are, while removed, see if the actuator is cycling when the ignition is turned on. If it is you should not get a FI light on, but you may if a cable or the valve itself is seized up and is stoping the actuator from cycling
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #3 of 13 Old 03-09-2009, 05:50 AM Thread Starter
Big Head's Avatar
Images: 32
Ok... Ill try it...
The strange to me is that it was perfect before I pushed it into garage in the October and now there is a problem...
Big Head is offline
post #4 of 13 Old 03-09-2009, 08:42 AM
sextaafondo's Avatar
If everything that Thrill said above is checked OK, then disconnect the battery over the night to power reset the ECU.
sextaafondo is offline
post #5 of 13 Old 03-09-2009, 08:49 AM Thread Starter
Big Head's Avatar
Images: 32
OK... Ill check it and than Ill ask you guys again...
I also tride to ride the bike on Saturday and everything was perfect... no problem! Only the LED was blinking...
Big Head is offline
post #6 of 13 Old 03-09-2009, 09:12 AM
When checking, remember NOT TO loose the valve cables by trying to remove the pulley center bolt of the valve actuator device. You will break the internal mechanism.
post #7 of 13 Old 03-09-2009, 09:26 AM Thread Starter
Big Head's Avatar
Images: 32
I know... thats clear to me... I have to wait till weekend and then Ill check it...
Big Head is offline
post #8 of 13 Old 03-09-2009, 10:25 AM
10roller's Avatar
when you start the bike you should be able to hear the servo motor in the tail momentarily.
10roller is offline
post #9 of 13 Old 03-09-2009, 03:00 PM
kingoose's Avatar
Send a message via MSN to kingoose
Hi,
Another guy from Europe. If you just installed a couple of slip on's on your 06 10, and removed the butterfly from the exhaust, you need to "fool" the ECU because it can't detect the position of the servo that moves the butterfly cables.
Akrapovic and Leo Vince sells a small bracket that substitutes the cable pulley on the servomotor. This bracket bolted onto the servo, reproduce the same positions (fully open and fully closed during the checking) as the cable does, so your FI light will go off. Be careful using your bike without this gadget, because the servo seizes easily and it really expensive for no use.
At the thime of loosening the pulley bolt that attaches it to the servo be careful, first block the pulley and then loosen the bolt (inside the servo there are several plastic sprockets that breaks easily).
Just that.
Want more?? Visit www.gassattack.com
kingoose is offline
post #10 of 13 Old 03-09-2009, 08:03 PM
Originally Posted by kingoose View Post
Hi,
Just that.
If you leave the actuator device connected, you can replace the OEM exhaust headers (including the valve) and remove the driving cables and you wont have an FI.
