Gen 3: 2008-2010 ECU fueling or ignition problems... - Kawasaki ZX-10R.net
 2Likes
post #1 of 19 Old 04-03-2011, 07:15 PM Thread Starter
PatrickG's Avatar
Images: 15
I have an issue with an 09' zx10r with approximately 1190 miles on it. I took it for a ride yesterday and it will not rev or accelerate past 9500 RPM's in any gear. I can put it in neutral and it will rev past 9500 all the way to the rev limiter near 13000.
I took it on the road and did numerous pulls in 1st, 2nd, 3rd and it hits a brick wall at 9500 and will not go past it no matter how many times I tried it.
Bike has no Power Commander but has a 2 bros slip on.
So, to ensure it wasn't the fuel pump I swapped over my 05' zx10r fuel tank in place of the 09' fuel tank. It doesn't mount up the best but it works for some troubleshooting. I took it back out last nite and it did the exact same thing, it won't pull past 9500 in gear but will rev to the limiter in neutral.
I am concerned it maybe the ECU now, since I seen someone post up something close to the same problems as I have now but the member posted up what fixed it or if it got fixed.
It idles perfectly fine, starts up on the first hit of the starter and sounds great. So that rules out spark plugs and a few other things.
Any ideas?
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #2 of 19 Old 04-03-2011, 08:14 PM
KIRK_ADAMS's Avatar
Does it have a power commander...if so, try un hooking it and going for a ride
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #3 of 19 Old 04-03-2011, 08:17 PM Thread Starter
PatrickG's Avatar
Images: 15
Damn forgot to put the mods in.. I'll edit the first post but no power commander
PatrickG is offline
post #4 of 19 Old 04-03-2011, 09:59 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
fuel cut off?? or im thinkin the same about ecu...maybe a mess up on the flash from kawi..
Weird though.....I know yami had an issue with the r1 back in 07 or 08...@ 4000 or 4500 it flat spotted...Yami reflashed it and all was good....call kawi to see what the prob or if there is a recall issue...
Somethin else too,a local shop told me that the wire harness is a smidge short and sometimes a cpl of the pins from the wire harness just barely loose connection to ecu...Chk that before you do anythin..
craig_sez is offline
post #5 of 19 Old 04-03-2011, 11:57 PM
fireman69's Avatar
check to make sure your secondary injectors on the top of the air box have connectors that are clean and well connected. This sonds exactly like what happens when the secondaries are not firing proper.
fireman69 is offline
post #6 of 19 Old 04-04-2011, 12:24 AM Thread Starter
PatrickG's Avatar
Images: 15
Thanks for the thought. I haven't had a chance to take the top of the airbox off yet to ensure they are sprayn correctly yet. That does sound like a reasonable explanation and much cheaper than a new or used ECU.
PatrickG is offline
post #7 of 19 Old 04-04-2011, 12:26 AM Thread Starter
PatrickG's Avatar
Images: 15
It's supposed to rain over the next few days and that will give me time to check out the connectors and wiring.
PatrickG is offline
post #8 of 19 Old 04-04-2011, 10:31 AM
fireman69's Avatar
You don't need to check to see if they are spraying correctly. You need to check the connectors to make sure they are clean and intact. I had one connector on my Bazzaz push a pin out to the point that it no longer made contact. It looked like it was together and clean, however the one pin was not in the connector. This one pin allowed the bike to do exactly what your is doing.
Good luck my friend. I hope it is something simple like stated above. It usually tends to be.
post #9 of 19 Old 07-21-2017, 01:15 PM
I'm having the same issue
Reviving a crazy old post lol...
So I'm having the exact same issue, does anyone know what ended up being wrong? I've got quite a few more miles, 74,000, but my 08 runs like a champ except for not revving above 9500 or so on the road.
I'll start by checking the connections mentioned above, but I definitely haven't noticed any wiring issues offhand while doing maintenance around it over the years... of course I probably wouldn't have noticed a very slightly loose pin in a connector though. Speedohealer and XTRE are all I currently have as far as electronic mods.
bikerman7502002 is offline
post #10 of 19 Old 07-21-2017, 03:44 PM
SpazOnaZX's Avatar
Given your mileage and symptoms, it's likely the fuel pump... a simple flow test will tell the tale. There are many threads that cover the subject here if you search. :)
SpazOnaZX is offline
