Dyno graph dip.. thoughts? - Page 2 - Kawasaki ZX-10R.net
 9Likes
post #11 of 18 Old 06-27-2017, 12:26 PM Thread Starter
Originally Posted by Capncalyx View Post
Yea but what was done during the flash? Does it still have the cat?
No cat.. i do remeber him saying he didnt do much with the secondaries for the (driveability) part.
Srocco50 is offline
post #12 of 18 Old 06-27-2017, 12:53 PM
SkyDork's Avatar
Originally Posted by Srocco50 View Post
Cool.. if u looked at the picture. It clearly says 14 zx10r
I can't read the picture because it's sideways. And there's no point at looking at a pic if the text doesn't spell it out clearly. Plus it's not very legible on the mobile app.
And who did the reflash and what software did they use? The secondary butterfly valves are the primary way the ECU kills power to the motor for the topspeed restriction and the traction control intervention. So, the "guy" saying he didn't touch them for "driveability" reasons is completely suspect as to his capability.
Capncalyx and NinjaLife like this.
#WordCrimes
SkyDork is online now
post #13 of 18 Old 06-27-2017, 01:12 PM Thread Starter
Ok sorry about that.. it was woolich software.. the bike runs and pulls great.. but it just feels upstairs in power it suffers some.. witch i would belive is the secondarys closing a bit.. as it would stock
Srocco50 is offline
post #14 of 18 Old 06-27-2017, 01:57 PM
Capncalyx's Avatar
If you guy "didnt touch" the secondary flies - that would explain it. Easy enough, they are still in effect and killing top end power. Kinda a waste of a flash if the restrictions arent removed. Now yer gonna have to flash and dyno again. Or, i would.
Srocco50 likes this.
*Official winner of one Riflemans 1/5 insert
"Stop being such a Sheila, Peter" - Peter's Dad
Capncalyx is offline
post #15 of 18 Old 06-27-2017, 09:37 PM
Victors's Avatar
There's no way it's a STV issue.. it's likely a fuel or tikming issue
2013 10R
2007 650R
2016 10R
Victors is offline
post #16 of 18 Old 06-28-2017, 10:44 AM
SpazOnaZX's Avatar
...at great risk to my cervical vertebrae, I looked at that graph a little closer.
It looks fine. It's a stock cam'ed/stock timing bike that holds on to peak torque up to 12000 rpm.... and that's great. if you were to scale the RPM similar to the graph 10Arghh posted, you'll notice they have the same shape & characteristics.... the big difference is that you're trying to rev it to nearly 14 grand.... party is over at 13K unless you want to change your cam timing up to match those extra revs. Otherwise, you made huge gains in power over stock with a broad spread of smooth torque.... no problems there.
Oh, and on a personal note, it looks a touch lean as well. I usually find best mph in the 12.5-13:1 area... a good portion of that run is above 13.5:1 or even touching 14:1 in places.... I think you'll find that when it's loaded down in the top of 3rd or 4th that it will like a slightly richer afr than you have there a little better. :)
SpazOnaZX is offline
post #17 of 18 Old 06-28-2017, 02:12 PM
mpp12's Avatar
what he said...
stock cam timing looks good..
Also the secondaries... only restrict on the very top end...
stock map except on the very top end is very good...not perfect but good..
mpp12 is offline
post #18 of 18 Old 06-28-2017, 06:35 PM Thread Starter
Thanks Guys.. i removed the secondarys and o my what a differance! ill get it strapped up to dial in aswell
Srocco50 is offline
