Clutch pressure rod problem, How frequent? - Kawasaki ZX-10R.net
post #1 of 23 Old 01-10-2008, 09:17 PM Thread Starter
Clutch pressure rod problem, how frequent?
I am wondering if many people had the following problem. The tip of the clutch rod worn out. I was thinking my clutch was going bad because I was not able to launch properly at the drag strip but after reading a thread from "fordfasterr" here I realise that it could be the same problem show in the picture and it fact it was exactly that.
The image was taking from "fordfasterr" but it's exactly the same thing that happen to me with less material remove probably because of the low mileage of my bike. Look at the tip of the center rod, it's all worn out.
My bike is a 2005 and only have 10 000 KM (6,215 miles).
Who had or heard of this problem and witch bike year of zx10r it happens?
I know of 3 person now including myself with the same problem and my worry is that all are on 05 year and I am a bit scare that it may be related on another bad parts like the clutch cover dimension or other related part on the 05 model and if it is the case the problem may come back later.
2005 RAW TITANIUM ZX-10R:
04 /05 Kawasaki race intake cam, 0.45mm head gasket, full titanium akrapovic exhaust, Woolich racing LBP, PCIII USB, BMC race air filter,
wideband O2 sensor, annitori Rl QS, Hyperpro RSC steering damper, Shorai lithium battery, gipro ds gear indicator,
healtech Shift light pro, ZX-14 front caliper
2002 ZX-12R all stock
1993 MUSTANG LX 5.0L, N/A 400 HP, 11.82@116 MPH on 17" E.T. street tire
STEPH93LX is offline
post #2 of 23 Old 01-11-2008, 10:20 AM
maze's Avatar
It happened to me as well. I bought two of them " only after buying a whole new clutch assembly" so that I would have a back up. The berrings wear out as well so replace those. It's a good insurance policy to have a few spares just in case. Good luck.
The only thing nessecary for the triumph of evil is for good men to do nothing
"sometimes in order to truly live life you must risk it."
You hit the lights, I hit the gas...
THERE ARE ONLY THREE SPEEDS, FAST, VERY FAST, AND OH SHIT!
maze is offline
post #3 of 23 Old 01-11-2008, 04:43 PM Thread Starter
What is your mileage and how many time you had to replace those parts since you have your 2004 ?
For the parts you mean I should change the rod, the lever that pull the rod +
the ball bearing.
Thank you for your input!
post #4 of 23 Old 01-11-2008, 07:20 PM
CountDokoo's Avatar
Me too. I had that problem. Replaced it twice already and now i always have one spare on standby. :)
A tell tale sign of your rod wearing out: the distance needed to released the clutch lever will become shorter.. Adjusting the clutch will help somewhat but then the problem will just come back again as your rod wears even more...
CountDokoo is offline
post #5 of 23 Old 01-11-2008, 07:32 PM
bluedevil's Avatar
really never heard of a major problem on this site....I have to think there is another reason for this happening for you guys....replaced mine a few months ago with 18k and yes I do drag racing not a scratch on the pin or the pulling arm on the clutch cover
bluedevil is offline
post #6 of 23 Old 01-11-2008, 08:33 PM
RussMcB's Avatar
I got advice from a fellow ZX10R-powered race car owner that they wear out and that it's a must have spare to have handy at the track.
RussMcB
F1000 (SCCA Formula Car w/ '07 ZX-10R engine) - Sold in 2010 :-(
'99 ZRX1100
Marietta, GA USA
RussMcB is offline
post #7 of 23 Old 01-11-2008, 08:47 PM
bluedevil's Avatar
after reading my own post I see I wasn't clear...I replaced my clutch and noticed there was NO damage or wear on the PIN....sorry but had to make it clear.
bloo
post #8 of 23 Old 01-12-2008, 08:29 AM
redline659's Avatar
Been there done that, the thing that sucks is if you put some serious springs in there to hold power, the end will actually just break right off, hahahahah. I am in the process of making a new pin out of better material.
redline659 is offline
post #9 of 23 Old 01-12-2008, 09:52 AM
RussMcB's Avatar
Hmm. I wonder if you should make a batch? :-).
RussMcB is offline
post #10 of 23 Old 01-12-2008, 10:28 AM Thread Starter
For those who already answer to this thread and for the other that may do it later,
what motor year and how much mileage before you had to change those parts?
I hope it's more than me at only around 6,000 miles!
Also "redline659" I let us know about that custom replacement pin please.
