Clutch pressure rod problem, How frequent? - Page 2 - Kawasaki ZX-10R.net
post #11 of 23 Old 01-12-2008, 01:04 PM
redline659's Avatar
Will do, I have hit quite a few roadbumps with mine,,, clutch basket rivet snapping off trashing motor #1, basket pin end snapping off,,, pinching ring lands, spinning bearings,, hahahah,,,, The rods are still good though.... Mine gave up at 600 miles heheheheh,,,, Heads up on the 04-05 valve spring retainers, they are cast aluminum,,,,,, JUNK,,,,,
redline659 is offline
post #12 of 23 Old 01-14-2008, 04:55 PM Thread Starter
Only 4-5 persons total who had this problem in the past???.
We must be very unlucky !
2005 RAW TITANIUM ZX-10R:
04 /05 Kawasaki race intake cam, 0.45mm head gasket, full titanium akrapovic exhaust, Woolich racing LBP, PCIII USB, BMC race air filter,
wideband O2 sensor, annitori Rl QS, Hyperpro RSC steering damper, Shorai lithium battery, gipro ds gear indicator,
healtech Shift light pro, ZX-14 front caliper
2002 ZX-12R all stock
1993 MUSTANG LX 5.0L, N/A 400 HP, 11.82@116 MPH on 17" E.T. street tire
STEPH93LX is offline
post #13 of 23 Old 01-14-2008, 10:11 PM
redline659's Avatar
Hahah, nope its a well known fact in the drag racing world
post #14 of 23 Old 01-14-2008, 10:12 PM
redline659's Avatar
when you start throwing big clutch springs in them,,,, the end will actually just snap off,,,,,, isnt that nice
post #15 of 23 Old 01-14-2008, 10:57 PM
RussMcB's Avatar
I tried to be liberal with anti seize when I assembled mine, but I'm crossing my fingers it wont break off. I have stiffer clutch springs. I'm an interested buyer if new and improved parts are available.
RussMcB
F1000 (SCCA Formula Car w/ '07 ZX-10R engine) - Sold in 2010 :-(
'99 ZRX1100
Marietta, GA USA
RussMcB is offline
post #16 of 23 Old 01-14-2008, 11:28 PM
1slow10's Avatar
This sounds like something fun to look forward to....great LOL.
1slow10 is offline
post #17 of 23 Old 01-15-2008, 08:18 AM
maze's Avatar
Originally Posted by STEPH93LX View Post
What is your mileage and how many time you had to replace those parts since you have your 2004 ?
For the parts you mean I should change the rod, the lever that pull the rod +
the ball bearing.
Thank you for your input!
I had to replace it twice only because the berrings were bad the first time and the new rod got chewed up because of that. After those were replaced than it was all good.
The only thing nessecary for the triumph of evil is for good men to do nothing
"sometimes in order to truly live life you must risk it."
You hit the lights, I hit the gas...
THERE ARE ONLY THREE SPEEDS, FAST, VERY FAST, AND OH SHIT!
maze is offline
post #18 of 23 Old 01-15-2008, 10:53 AM Thread Starter
Good to know. I will certainly change the bearing at the same time.
Thank you!
post #19 of 23 Old 01-15-2008, 11:11 AM
maze's Avatar
As for mileage I don't know off the top of my head from when it happened. I drag race it and so I'm pretty hard on clutch parts. I also have stiffer springs in but only three not 5 cause I was told that that would give me the desired outcome that I was looking for at the time. It works well.
maze is offline
post #20 of 23 Old 01-15-2008, 02:03 PM
redline659's Avatar
We were trying to hold in 260 hp with the stock setup so we had in HD springs and shimshahahah and it was still eating clutches but it snapped off along with some other things
