Gen 4: 2011-2015 Cat removal with K&N airfilter - Page 2 - Kawasaki ZX-10R.net
 6Likes
post #11 of 15 Old 10-20-2017, 06:49 AM
GreenOne's Avatar
Originally Posted by romanovalentin View Post
Thanks for all the information! I guess I'll just find a shop to help me tuning the bike next year. Yesterday I replaced the cat for the midpipe. There is a place for the lambda sensor in the midpipe but I had to use an adapter to make it fit. Could you tell me what the reason would be to skip the powercommander?
Ok. The bung is for the larger 18mm wideband sensors then, but the adapter works just fine as long as the sensor tip is in the exhaust flow.
If you use the power commander, you would need a o2 optimizer as well to control the closed loop area. And it will still not be 100% optimal in that range. The o2 optimizer is another $100 in the US. Probably more in your country.
And you should get it tuned in a shop on top of the 500+ bucks you will pay for just the PCV hardware.
Editing the ECU gives you a lot of tunable options for probably about the same price. Find a shop who can do this. Have a look here for the possibilities.
2011-2015 Kawasaki ZX10R - USB (Mitsubishi) v3 Package
romanovalentin likes this.
I`m just in for the ride
GreenOne is offline
post #12 of 15 Old 10-20-2017, 07:04 AM
GreenOne's Avatar
There is only one little problem guys....
I tightened the straps around the joints but there is a small amount of air leaking and I have no idea how that would be possible. Any ideas on how to fix this?
Unfortunately It isn't possible to add .mp4 files, how am I ever going to be able to show you guys the vid?!
The link pipe might have a slight oval shape. First try moving the clamps around a little in all directions. If nothing helps you can try with some super thin "exhaust leak fix aluminium tape" from a auto parts store. On the inner flange, as a filler. If needed in combination with exhaust mounting paste.
If the leak is before the o2 sensor you should get it fixed. If it is after, it`s just more of an annoyance.
GreenOne is offline
post #13 of 15 Old 10-20-2017, 08:37 AM Thread Starter
romanovalentin's Avatar
Thanks! I will get into it!
romanovalentin is offline
post #14 of 15 Old 10-20-2017, 08:50 AM Thread Starter
Well, unfortunately it is at both sides. The air escapes around the area where the bolt tightens the clamp. See attached image for an example. At both sides, such clamps are used where on the web, I often see those completely closed clamps. I'll try to move the clamps around and see what happens otherwise use the leak fix tape!
Again, thank you very much for sharing the knowledge
post #15 of 15 Old 10-20-2017, 09:00 AM
GreenOne's Avatar
I see. You can usually find better fully closing clamps at the auto parts store to try as well before messing with the tape and paste. Just measure the size you need and see what you can find. I am using those type of clamps on my bike. Good luck!
GreenOne is offline
Tags
cat, midpipe
