Gen 3: 2008-2010 Carpenters Heavy Duty Valve Springs - Kawasaki ZX-10R.net
 4Likes
  • 1 Post By Porschenut
  • 1 Post By gaz
  • 2 Post By michael4012
post #1 of 10 Old 04-27-2018, 02:57 PM Thread Starter
Kawasakigreen2008's Avatar
ok so im split between needing to get heavy duty valve springs or not. i have one person telling me i need them and another saying stock one will work just find. Im putting JE drop in pistons in my 2008 zx10r and my compression is going from 12.9:1 to 13.7:1. so ive been told i need heavy duty springs by one person and i dont need them by another. i dont want to spend the money if i dont have too. can you guys help me out with this plz
Kawasakigreen2008 is offline
post #2 of 10 Old 04-27-2018, 04:37 PM
Porschenut's Avatar
I thought that heavy duty valve springs were required to eliminate valve float when increasing rev limits or changing a cam lobe profile?
How would increased compression cause the valves to stay open?
SkyDork likes this.
Porschenut is offline
post #3 of 10 Old 04-27-2018, 04:45 PM
SkyDork's Avatar
Originally Posted by Porschenut View Post
I thought that heavy duty valve springs were required to eliminate valve float when increasing rev limits or changing a cam lob profile?
The springs are used to close the valves. The compression force will try to close the valves. So increased the combustion pressure will cause the valves to close tighter. Putting heavier springs in there to do the same thing is pretty useless if that's the only change. If the cams are modified, revs are increase, or forced air induction is used then the springs might be needed. Valve float is your enemy there.
#WordCrimes
SkyDork is offline
post #4 of 10 Old 04-27-2018, 04:55 PM Thread Starter
ok kool so sounds like i dont them great more money for other parts for this build Thanks
post #5 of 10 Old 04-27-2018, 07:20 PM
gaz
i've yet to see a drop in piston zx10 run any faster than a stk piston with compression mods. i've had 2 customers bikes, not my choice, not impressed. no need for hd valve springs as carpenters unless radical cam profile, forced induction, or nitrous.
Kawasakigreen2008 likes this.
gaz is offline
post #6 of 10 Old 04-27-2018, 10:50 PM
michael4012's Avatar
Needlessly using HD springs will Zap a Horse Power or 2. Carpenter will sell you anything, As stated unless radical changes to cam profile ie, where valves close faster due to increased lift or longer duration HD springs just make it harder to turn the engine.
gaz and Kawasakigreen2008 like this.
[SIGPIC][/SIGPIC]192MPH stock engined 2008
michael4012 is offline
post #7 of 10 Old 04-28-2018, 08:58 AM
gaz
my experience with drop in pistons is they are a waste of money. cost of pistons, engine has to be pulled, broken completley down, rods removed from crank, reinstalled(which is a whole new process),
cylinders honed, engine reassembled and reinstalled, figure about $1500+ besides the rod/crank issues created. not aware of any 13.7 je pistons, just 13.5. can easily achieve that with mill and adjusted squish for about $150. if ur a street rider, be aware any compression mods increase engine temps so how and where u ride should be a primary consideration. thin hg, good performance valve job, int. cam or degreed stk. cams, good exhaust, and tune, that gen 3 will be streetable and a handful.
gaz is offline
post #8 of 10 Old 05-09-2018, 11:57 AM Thread Starter
Well gaz this is my plan, i was trying to do a budget build with my gen3 and this is what me and my buddy came up with
-Lighten & balanced crank, 13:7.1 wossner drop-in pistons (NOT JE MY MISTAKE), Complete valve job, gen3 racing intake cam and gen2 stock exhaust cam degreed with a retune.
ive only spent about $1100 just from that list but i was at 166rwhp with just bolt-on parts, im hoping to be close to 175- 180. My biggest problem is i cant find any solid degree number for that cam combination. and now that you say that i should have gained my compression the head with
milling and thinner head gasket.
post #9 of 10 Old 05-09-2018, 04:18 PM
gaz
not knocking ur build, just trying to help. have'nt delt with wossners in a zx10, but have worked with je's and wiseco. check ur deck height closley, the je and wiseco pistons both have raised compression height tightening up the squish, so u have to measure and determine which thickness hg will work to provide minimium squish without piston to head contact. gen 3 race int, stk gen 1-gen 2 ex cam is a potent combo. my cam combo and used on a couple of other builds. degreed those cams to several different lobe centers, by far 110-111 int and 108 ex. made best power/strogest powerband. well prepped head, those cams, good tune i make 189-193 rwhp on mr12, so figure about 180-185 on pump gas. your goals are in line. good luck with build.
gaz is offline
post #10 of 10 Old 05-10-2018, 06:04 PM Thread Starter
Ya i previously had a .45mm HG on there but with the 13.7:1 pistons that are going in, im alittle worried about putting the .45mm HG back in. (if it even fits). I dont want to have to run race gas because of too much compression. But all in all we are going to double/triple check the piston to valve clearance, cuz i would hate to spend all this money just to blow it up when i start it. And thanks for the cam numbers, ive been wrecking my brain trying to find a starting point. thanks for the info keep it coming.
