Gen 4: 2011-2015 Battery drain - Page 2 - Kawasaki ZX-10R.net
post #11 of 16 Old 03-03-2017, 08:21 AM
C3L1CA's Avatar
Here is the process in the manual to check the stator and the regulator/rectifier.
I'd check those before you start throwing money at it.
ID:	393578   Click image for larger version
ID:	393586   Click image for larger version
C3L1CA is offline
post #12 of 16 Old 03-04-2017, 11:25 AM Thread Starter
Thanks.
So I'm getting around 60V AC at the alternator terminals going into the reg/rec when revving to 4000 RPM, but I only get something like 0.2V DC coming out of the reg/rec.
This is putting the multi-meter on the BK/W and BK/Y wired terminals.
I would have thought the voltage should be much higher coming from the reg/rec.
Are these the correct terminals to measure from, and what should I be seeing from a healthy reg/rec?
10Arghh is offline
post #13 of 16 Old 03-04-2017, 01:01 PM
Originally Posted by 10Arghh View Post
Thanks.
Did you check the resistance as for the manual?
Simon0721 is offline
post #14 of 16 Old 03-04-2017, 03:33 PM Thread Starter
I just went by this...
If the output voltage shows the value in the table, the alternator operates properly. The regulator / rectifier is damaged.
Also, the multimeter didn't have a 1k Ohm range as far as I could tell.
10Arghh is offline
post #15 of 16 Old 03-05-2017, 04:29 AM
Almost sure the regulator is bad. With a resistance test you could be 100% sure, since a new regulator costs around 250$.
post #16 of 16 Old 03-13-2017, 09:13 PM Thread Starter
Problem solved.
New reg/rec, new battery and the bike feels like it has gained some BHP, plus no more rich running.
Seems the power problems may have caused a weak spark, resulting in unburnt fuel.
Gonna change oil and plugs soon.
10Arghh is offline
Tags
battery, battery replacement
