Gen 5: 2016 -> Autoblipper ripping me off the bike - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 17 Old 04-25-2017, 07:41 AM
Originally Posted by tdh View Post
I enabled it on mine last year and then turned it back off shortly after. I didn't like it.
I've ridden some bikes that it works perfectly and others that are useless.
bbsteinnewyork is offline
post #12 of 17 Old 04-25-2017, 10:48 AM
Can't you just drop to the required gear and modulate the clutch on the ZX10R?...like the Moto2 boys do
10Arghh is offline
post #13 of 17 Old 04-25-2017, 01:53 PM
dricked's Avatar
That's how you use the slipper clutch to back it in. Auto blip is different.
dricked is offline
post #14 of 17 Old 05-19-2017, 11:41 AM
Yui
Yui's Avatar
Images: 12
Sorry guys, Are you talking about "autoblipper", downshifting with OEM quickshifter, right?
I have one question: This feature exists in the OEM 2017 model, or needs the Racing ECU installed?
I read a lot about quickshifter on upshifting, but I can't find any article where explain if it works downshifting too.
Thanks.
Yui
ZX10R 2005, Kevlar brake hoses, Lowering bones, Intake kit camshaft, Leovince Evo2 full Exhaust, Brembo master brake 19x18, Fiberglass fairing, Brembo M4 Calipers, PVM Wheels, Axis front Rotors.
Yui is offline
post #15 of 17 Old 05-19-2017, 12:02 PM
SkyDork's Avatar
Thanks.
Yui
No, you cannot use the autoblip in stock form. The OEM quickshifter is used for full throttle upshifts without touching the clutch lever. If the ECU is reflashed with the capability to autoblip, or the race ECU is installed, then the OEM quickshifter can be used for downshifting as well. Autoblip has to be able to control the throttle valves to momentarily rev-match the RPM on downshift. It requires more control than the upshift does. And unless that's enabled through the ECU, don't try downshifting without using the clutch like normal. That's a quick way to fuck up a gearbox.
#WordCrimes
SkyDork is offline
post #16 of 17 Old 05-19-2017, 04:47 PM
turtle1000's Avatar
Thanks.
Yui
It only comes enabled on zx-10rr
More cowbell
turtle1000 is offline
post #17 of 17 Old 05-24-2017, 11:11 AM
Yui
Yui's Avatar
Images: 12
Thanks for the info.
I'm planning to buy a new bike soon, and I'm between Zx10r and S1000rr (because this one have autoblip)
Do you know if exist any aftermarket module to have autoblip? Some ECU from bazzaz or dynojet maybe do this?
Yui is offline
