All Gens: So, your "FI" light is on..... - Page 4 - Kawasaki ZX-10R.net
 6Likes
post #31 of 60 Old 04-07-2015, 09:26 AM
tdh
tdh's Avatar
Minor correction to original post. Although the FI symbol is used for indicating faults, it doesn't actually stand for "Fault Indicator" but rather "Fuel Injection". I apologize for that. :)
tdh is offline
post #32 of 60 Old 04-07-2015, 09:45 AM Thread Starter
SkyDork's Avatar
Where are you getting that info from? I think that was the origination in the older models as it was meant to indicate problems with that system specifically, but the system has become more robust than that and deals with errors associated with the TC system, ABS, ESD, etc, etc.
I'm cool if you wanna call it Fuel Injection, or Fault Indication, or Fucking Incorrect....just don't call it an F1 light.
dudewhrsmybike likes this.
#WordCrimes
SkyDork is offline
post #33 of 60 Old 04-07-2015, 09:57 AM
tdh
tdh's Avatar
From the owner's manual (page 56 on the GEN4). This has actually been a debate on other forums I frequent. :) You won't find it called Fault Indicator in the service manuals or in the Owners manuals for either the ZX10 or the ZX6. But to be honest, you'll be hard pressed finding it called a "Fuel Injection Warning Symbol", except for on a couple of pages in the Owners manual. But then, it's also not called a "Valve Cover" but instead a "Cylinder Head Cover". Details, details. :)
SkyDork likes this.
tdh is offline
post #34 of 60 Old 04-07-2015, 10:13 AM Thread Starter
SkyDork's Avatar
While you're right about the terminology in the manual, it's still more descriptive for most people to leave it like it is. I still think that's a legacy term from the older models without all the fancy whiz-bang electronics. The FI system has morphed into much more that these days and encompasses more than strictly the fuel injection system.
So, I'll have to give you one of these and one of these at the same time.
#WordCrimes
SkyDork is offline
post #35 of 60 Old 04-07-2015, 10:15 AM
tdh
tdh's Avatar
Actually DFI encompasses a lot and believe it is still accurate. I could be wrong but I don't believe it indicates a problem that isn't related to DFI. Traction control actually does relate to DFI. For example, from the Service Manual:
User Mode
The ECU notifies the rider of troubles in DFI system,
ignition system, S-KTRC system and immobilizer system
(equipped models) by lighting or blinking the warning
indicator light (LED) [A], FI warning symbol [B] and immo-
bilizer warning symbol [C] when DFI, ignition, S-KTRC and
immobilizer system parts are faulty, and initiates fail-safe
function. In case of serious troubles, ECU stops the injec-
tion and ignition operations.
tdh is offline
post #36 of 60 Old 04-07-2015, 10:21 AM Thread Starter
SkyDork's Avatar
Yes, but the ABS and ESD do not. A CANBus error between the ECU and the instrument cluster have nothing to do with the DFI, but still triggers an FI warning.
If you look at the Gen 3 manual, the errors were part of the DFI chapter. For the Gen 4, they broke them out into their own chapter. The DFI and Self Diagnosis are 2 separate things now. As the bikes become more sensor and software based, the warning system has to advance with it. To me anyway, the system has progressed.
#WordCrimes
SkyDork is offline
post #37 of 60 Old 04-07-2015, 10:23 AM
tdh
tdh's Avatar
I believe you are wrong about ESD. If there is a fault in the ESD the DFI will adjust power and indicate there is a problem that is causing a change by the DFI by flashing the FI warning symbol right? I would have to check on that, and probably will. :) I guess what I am saying is Kawasaki does include all of that stuff into DFI because DFI is used to control what the engine is doing based on feedback from those other components.
tdh is offline
post #38 of 60 Old 04-07-2015, 10:30 AM
tdh
tdh's Avatar
Dang, all I have is an electronic version for the 2011 service manual. No ESD in that. Anyone have an electronic copy of the Service manual for '13-'14?
EDIT: Disregard! Found it thanks to SkyDork! :) And yes, it appears the ESD and FI ECUs are tied together.
tdh is offline
post #39 of 60 Old 04-07-2015, 10:58 AM Thread Starter
SkyDork's Avatar
There's a first time for everything.
#WordCrimes
SkyDork is offline
post #40 of 60 Old 04-07-2015, 11:04 AM
tdh
tdh's Avatar
Sorry, don't mean anything personally. I really enjoy reading your posts and I like learning as much as I can about the machine I get on. :) Interested to know about your username. I assume some relation to aviation. :)
tdh is offline
