Gen 3: 2008-2010 Afr - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 15 Old 01-02-2018, 07:21 AM
I know i've asked this before, but, anybody have a good estimate for AFR for oxygenated fuel? I'm running Renegade SX4 fuel which is unleaded 97 octane and 3.6% oxygenated. The bike is solely for drag racing.
I have a pc5 and wideband on it, which I can datalog with. I think i'm somewhere around 12.5 or 13:1, but it's been since september since i've touched it or look at data.
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, cat delete, V&H slip-on, BMC race, lowered, stretched,-2/+5
MORE TO COME
medicbaldwin is offline
post #12 of 15 Old 01-02-2018, 03:35 PM
Victors's Avatar
Air fuel is air fuel regardless what fuel you run. You just need more of it for oxygenated. Start safe, around 12.7ish and lean it out till it slows down.. I wouldn't like running more than 13.2 on the top end.
2013 10R
2007 650R
2016 10R
Victors is offline
post #13 of 15 Old 01-02-2018, 10:46 PM
13 seems to be the popular number. I was running at 13 with pump gas. I changed the tune last year after putting some oxygenated fuel into the bike but didn't pay much attention to the afr. More than likely, it's really FAT.
'08 10R, Lime/Black
MORE TO COME
post #14 of 15 Old 01-03-2018, 01:24 AM
SpazOnaZX's Avatar
If you're going to get serious about tuning and you plan on changing fuel types, start looking into using lambda readings instead of AFR. If you know your stoich for a given fuel and what stoich the AFR gauge is using you can eyeball/Kentucky windage it in there, but Lambda is always the same for a given application, regardless of the fuel you use.... makes it really handy if you use different fuels often.
EDIT: Simple, but somewhat helpful article http://blog.innovatemotorsports.com/...the-difference
SpazOnaZX is offline
post #15 of 15 Old 01-09-2018, 01:14 AM
Anybody familiar with or used Dynojet's Autotune? How much time does it need to figure out map changes? If it's more advantageous for me i'm considering selling my wideband commander and buying an Autotune, but, if it takes a good amount of time to figure out map corrections then i'll just keep on keepin on with my current setup.
'08 10R, Lime/Black
MORE TO COME
