1st gen clutch basket into 4th gen - Kawasaki ZX-10R.net
post #1 of 9 Old 06-07-2017, 01:40 PM Thread Starter
aaron403's Avatar
What do i need to fit a 1st gen clutch and parts into a 4th gen?
aaron403 is offline
post #2 of 9 Old 06-07-2017, 07:12 PM
thundercoupe9's Avatar
Step 1 order a clutch kit for 1st gen zx10r.
Step 2 replace your 4th gen clutch with a gen 1 clutch.
Step 3 go ride it.
thundercoupe9 is offline
post #3 of 9 Old 06-07-2017, 08:56 PM Thread Starter
aaron403's Avatar
It's that simple just basket and plates or do I need more?
2013 ZX-10R | Woolich Racing Tuned | M4 GP | Riflemans Throttle Insert | 3D GP 520 -1/+2 | Sato Racing Rearset | Zero G Windscreen | LED projection headlamps | Respring & valving front/rear suspension | 110% Squid
aaron403 is offline
post #4 of 9 Old 06-08-2017, 12:14 AM
I don't recall saying anything about a basket in my reply.
post #5 of 9 Old 06-08-2017, 04:27 PM Thread Starter
aaron403's Avatar
I have talked to 2 dealers there is nothing called a "clutch kit" for oem.i have to order individual parts.
aaron403 is offline
post #6 of 9 Old 06-08-2017, 04:56 PM
SpazOnaZX's Avatar
The 'Kit' is typically a set of friction plates and a set of steel plates... some clutches will throw in the odd friction or steel thickness to keep it interesting. Some OEM kits even get a judder spring, and some with new pressure plate springs (and I highly recommend at least new, if not stronger springs in almost any OEM clutch).... but at the end of the day you just need the friction & steel plates. If the 'Kit' in question includes those yer good to go.
SpazOnaZX is offline
post #7 of 9 Old 06-08-2017, 11:34 PM
Sorry, disregard my replies.
post #8 of 9 Old 06-09-2017, 09:39 AM Thread Starter
aaron403's Avatar
Okay so thats kind of what i was thinking.i looked at the blow up from the 1st gen and it uses the same part numbers for the friction plate and steels just a different combination of them.
aaron403 is offline
post #9 of 9 Old 06-09-2017, 10:20 AM
SpazOnaZX's Avatar
No need for that... you had the absolute right of it, but sometimes it's hard to understand each other when thoughts get translated through keyboards. My attempt to clarify was a verbose agreement of your instruction.... maybe a borderline explanation. :)
