1078cc big bore kit install with goodies - Page 2 - Kawasaki ZX-10R.net
 9Likes
post #11 of 25 Old 10-18-2017, 12:15 PM
michael4012's Avatar
Originally Posted by badassjake View Post
motor is going in the bike next spring.
Although, the gen 4 cams in the Gen 1 head yeilded great results and survived my season of racing.
I suspect the Gen 4 head and cams will be an equal to that combo with long life and durability packed in.
The head will also compliment the gen 4 pistons better and yield a better power production.
I gotta say the chamber in the gen4 is vastly better than gen1 & is the reason the stock compression is superior, also the inlet tracks are far better as a matter of interest did you port out the gen1 inlets much?
[SIGPIC][/SIGPIC]192MPH stock engined 2008
michael4012 is offline
post #12 of 25 Old 10-20-2017, 02:22 PM
zapp's Avatar
Is this process easier than putting the Gen 4 cams in the Gen 1 head? Or does it require relocating bolt holes and such?
2005 Ti 10R
2014 1199 Panigale S
zapp is offline
post #13 of 25 Old 10-21-2017, 10:51 AM
The advantages for a 4 head over a 1 are numerous, all titanium valves with longer & thicker stems, & larger inlet buckets means you can use the highest lift cams, the chamber is much superior meaning you can get better flow & compression the inlet tracks are superior. The difficulty is moving the coolant inlet & fabricating some frame mount points to make it fit the older Gen's.
badassjake likes this.
post #14 of 25 Old 10-23-2017, 04:23 AM
I have the kit intake gen1 cam on my gen1 and was planning to put the stock gen4 exhaust cam and valve springs in combination with Carpenter retainers that I already have.
But I purchased a 2011 zx10r, tried it on the track and I did 9.32 @1/4 swb vs the 9.52 on my gen1.
So now I will sell my gen1 parts and tune my gen4.
Are the gen1 rods same as gen4 in dimensions?
I have a set of carrillo rods for my gen1 is it better to put them in my gen4 with 60-70 shot?
300ZX10R is offline
post #15 of 25 Old 10-23-2017, 06:22 AM
The Gen1 & 4 rods are the same dimensions yes mate only difference is the Gen4 has a beefier build making them heavier but stronger at high revs = less stretch. Incidentally Carpenter sells those retainers too everyone is was only the Gen1 retainers that were weak the other gens are good.
post #16 of 25 Old 10-23-2017, 06:24 AM
Sorry I hadn't answered the exacting question 60-70 shot yups I'd use carillo rods Iv had a small end go with just a 40 shot.
post #17 of 25 Old 10-25-2017, 01:21 PM
Did you have small end problem with 40 shot on gen4?
The main thing is that carillo don't sell rods for the gen4 and it has different part number for the 04-07 and 08-10.
What's the reason if they are all interchangeable?
300ZX10R is offline
post #18 of 25 Old 10-25-2017, 09:35 PM
gaz
i do a lot of nitrous builds, 60-70 shot too much to run safely and very hard to manage. smaller shot applied off the line usually produces best et/mph. just finished 05 gsxr1000 bone stock motor that was running 6teens@113 mph, added hd valve springs, hd clutch springs, cleaned/flowed all injectors, added walbro 255lph fuel pump, spray bar, nos mini nitrous controller, tuned on u4.4 with 32 shot measured on dyno . only a few passes made with best et 5.41/131 mph. bike makes 100 ft lbs torque. trick to going fast on nitrous is good consitient fueling, smooth power delivery.
gaz is offline
post #19 of 25 Old 10-26-2017, 12:39 AM
lol, what did you have to do gazx10, create a new account and start over?
gaz likes this.
Boxtradamus is offline
post #20 of 25 Old 10-26-2017, 12:41 PM
No mate it was a Gen2 2007, the part numbers for 06-07 and 08-10 are the same, the rods are the same
13251-0023-II
