Gen 1: 2004-2005 05 zx10r - Kawasaki ZX-10R.net
 2Likes
post #1 of 11 Old 07-09-2017, 01:19 AM Thread Starter
05 zx10r
I need help! I have a 2005 ZX10R which I have recently turned into a track bike. The stock from Tokyo Calipers are not doing the job. People say that certain other makes calipers fit and solve this problem. Any experience with this would be greatly appreciated.
bhemerzx10r is offline
post #2 of 11 Old 07-09-2017, 03:56 PM
badassjake's Avatar
CBR 1000 05+ is one of the hot tickets....some spacers required, but basic and easy.
badassjake is offline
post #3 of 11 Old 07-09-2017, 04:06 PM Thread Starter
After going thru the forum I found that a majority is saying the ZX6R or ZX14R Nissan Calipers. It was said that from 07-14 model calipers for the ZX6R and ZX14R are the same. I found a 2013 set of Nissan Calipers in mint condition. however the actual appearance differs from the 2012 calipers.
My question:
Is this difference just cosmetic, weight savings? or are the 2012 and 2013 ZX6R/ZX14R calipers different?
post #4 of 11 Old 07-11-2017, 06:22 PM
zx racer's Avatar
Wat you benefit from the newer calipers from a zx6, 14 is way better braking not weight savings
Sent from my SCH-I545 using Tapatalk
bhemerzx10r likes this.
05 ZX-10R SWB.
zx racer is offline
post #5 of 11 Old 07-11-2017, 09:23 PM
Upgrade the master. A master from a 2005-6 zx6r will do the trick. A radial MC upgrade is far more important than the calipers (though they won't hurt either)
JayBoCC2 is offline
post #6 of 11 Old 07-11-2017, 10:13 PM Thread Starter
I have purchased a racing brembo master cylinder. Brakes got really strange felling during track day. It seemed like no matter how hard I pulled the bike would not slow down.
post #7 of 11 Old 07-11-2017, 10:14 PM Thread Starter
so it is true that all ZX6R and ZX14R from 2007-2014 will work on my gen 1?
post #8 of 11 Old 07-12-2017, 06:55 PM
I believe so. I found a set of zx14r calipers for excellent price on ebay and fast shipping.
JayBoCC2 is offline
post #9 of 11 Old 07-14-2017, 02:22 PM
MC helps only so much...
The calipers are a FAR more effective upgrade. I switched MC first to a RCS19, a year later the calipers to ZX6R Nissin's. The calipers make a LARGE difference in braking performance.
MTFDarkEagle is offline
post #10 of 11 Old 07-17-2017, 09:28 AM
IT'S NOT THE CALIPERS
Sorry to shout but this is always the first thing people look at, whilst they overlook the brake fluid pump attached to the lever they actually pull to activate the brakes.
Change the master cylinder...Night and day difference on any Japanese bike, and cheaper than callipers.
Recommended order of upgrading brakes.
Fluid (use good quality Motul RBF 660 or other Dot 5.1)
Pads (Use decent sintered pads like SBS, Brembo)...If dry track only...Try carbon brake pads...You need to bed them in.
Braided brake lines (Goodridge, HEL they're basically all the same).
After all that, do the master cylinder...Accossata...Brembo...AP Racing...Unless you are a top level racer they're all the same and all better than stock.
Next discs...Personally I would just use Brembo.
Lastly callipers...Again Brembo or AP Racing...But this is serious performance level that I'd argue most don't need.
10Arghh is offline
