Michelin tire failure - anyone see the video? - Kawasaki ZX-10R.net
 5Likes
post #1 of 18 Old 02-08-2016, 08:04 PM Thread Starter
White Fang's Avatar
I guess Michelin had a pretty spectacular rear tire failure on Loris Baz' bike, it blew out on the front straight while testing. They are now pulling the "soft" compound tire from testing.
No one was hurt. Video is on youtube somewhere.
Sturm und Drang
White Fang is offline
post #2 of 18 Old 02-08-2016, 08:30 PM
Judge Dredd Mod
mr_honez's Avatar
A couple of links
https://youtu.be/vHenAQhF8H0
https://youtu.be/lJypSm1XySE
White Fang likes this.
BURNOUT.....
mr_honez is offline
post #3 of 18 Old 02-09-2016, 01:13 PM
...pucker...
hooligan317 is offline
post #4 of 18 Old 02-09-2016, 03:13 PM
TechX's Avatar
Yes Baz's suit recorded a 29.9 g impact on his shoulder. Michelin has a lot of homework to do if their going to make a tire that will work in Motogp.
TechX is offline
post #5 of 18 Old 02-09-2016, 04:40 PM
MotoGP: The Sepang Michelin incident?too tight a margin? | Sport Rider
Might want to give that a read... doesn't look like all the blame is on Michelin. Typical constructor blaming manufacturer and vice versa.
Tires seemed to be underinflated some and now internal TPS are mandated.
ZX10RArcher is offline
post #6 of 18 Old 02-09-2016, 05:11 PM
Didn't see the video ... did see a still of the tire...
I'd be blaming Michelin... Can't believe the tire was under-inflated to a lower pressure than is a race pressure.
And ... I've never seen a failure like that.
louemc is offline
post #7 of 18 Old 02-09-2016, 07:06 PM
The Pace
scout's Avatar
yeah, pro guys often hate Mich for a list of reasons. Usually psi pressure is sensitive. Mich corp got frustrated and pulled out of pros awhile back if I recall.
scout is offline
post #8 of 18 Old 02-09-2016, 08:04 PM
SkyDork's Avatar
It was the rear tire that failed.
Frankly, it's nothing new. Akira Yanagawa had a tire fail at 180+ mph and wadded the ZXRR Motogp bike years ago. Dunlop has had catastrophic failures in AMA at Daytona. It happens when they are trying to get the tires figured out and what pressures to run. It's all part of the process. A scary one for the riders for sure. And luckily no one has been seriously injured by it. But the process will continue and get sorted out and fixed. Michelin isn't a fly-by-night retreaded tire. They were the premiere tire supplier back when it was a competition and just need to get back in the game with these new bikes.
#WordCrimes
SkyDork is offline
post #9 of 18 Old 02-09-2016, 08:18 PM Thread Starter
White Fang's Avatar
Tire pressures are critical when you get to the low or high end of the range. That's why those guys get paid the big bucks.
Sturm und Drang
post #10 of 18 Old 02-10-2016, 08:00 AM
SkyDork's Avatar
Yes, Tire pressures are crucial. I'm sure they have baselines and calculations they go by to determine the tire pressures to start with. But there are tons of variables and data is the the key. They may have been experimenting with outlier pressures to see the response. Or Baz's riding style is that much different than the others who didn't have a problem and overwhelmed the tire, the bike wasn't setup properly and over stressed the tire, it could've developed a leak, had a manufacturing defect, he ran over some debris on track that compromised the tire, or it simply was a fluke. Considering no one else had a tire problem like this and that there hasn't been any concrete evidence of what the problem was, it's only speculation of why it failed so dramatically.
#WordCrimes
SkyDork is offline
