How bad are bluing tyres? - Kawasaki ZX-10R.net
 8Likes
post #1 of 16 Old 03-30-2017, 07:12 AM Thread Starter
Question How bad are bluing tyres?
Have an old set of Bridgestone R10s and a new set.
Was going to use the old set to set up my 2011 ZX10R at the track and then use the new set after, but the old set are going blue.
They are at least 5 years old, but they've always been kept in a cool dark environment (garage) when not on the track, and have been used with warmers.
Should I bin them and just use the new set?
PS. I'm not that fast
10Arghh is offline
post #2 of 16 Old 03-30-2017, 10:08 AM
LDH
LDH's Avatar
I would not use brand new 5 year old tires on the track let alone blue ones... A $300 set of tires is cheap insurance when it comes to keeping your bike shiny as it will cost you a lot more than a new set of tires if you wad it up.
banzai, SkyDork, mr_honez and 2 others like this.
LDH is offline
post #3 of 16 Old 03-30-2017, 03:39 PM
Judge Dredd Mod
mr_honez's Avatar
This. ^^
evilaugust likes this.
BURNOUT.....
mr_honez is offline
post #4 of 16 Old 03-31-2017, 10:05 AM
Capncalyx's Avatar
Im not a track guy...
YET!
But, isnt the blueing a sign of massive heat cycles? I mean, i just dont think i could bring that on by riding on the street but i guess its possible.
Dare i say tires could be one of the most important things on a bike, its your only tiny contact patch and connection to the earth.
Live Til You Die - QOTSA
We will all die but only a select few of us will ever truly live.
Capncalyx is offline
post #5 of 16 Old 03-31-2017, 10:16 AM
LDH
LDH's Avatar
Not really.... that is the oils and catalysts in the tire coming to the surface and it can happen on basically new tires if left long enough. The bluing can certainly be exacerbated by heat cycles and some brands or models of tires are way more susceptible to the discoloration than others, but it is part of the normal process of the tire. It's not even necessarily a bad thing, but there is a certain stigma associated with the blue color as it generally happens worse to shagged race tires.
LDH is offline
post #6 of 16 Old 03-31-2017, 10:31 AM
Capncalyx's Avatar
I learn'ded !
post #7 of 16 Old 03-31-2017, 10:39 AM
evallarta1's Avatar
While I completely agree with LDH and don't use the old tires, there are a couple things you can check. First look on the side of the tire and see what the tire date is. This will tell you EXACTLY how old they are. You may have owned them for 5 years, but they could also have sat on the shelf in the store for another year. So check the manufacture date.
Also like LDH mentioned, bluing is generally from normal head cycles and the releasing of the oils from the rubber. One thing to compare is put your thumb nail into the blued part and compare it to the same section of the new tire. More than likely the blued section will be much harder and less pliable than the new tire.
Velocity Calibrations
evallarta1 is offline
post #8 of 16 Old 03-31-2017, 11:32 AM
.net Most Followed Member
luis.pita's Avatar
I wouldnt ride 5 year old tires on a normal ride to work, and of course never on a track day. Can be gotten real good deals these days on new tires, so id yes get rid of them. By the way im a Michelin fan ;) super sticky stuff.
luis.pita is offline
post #9 of 16 Old 03-31-2017, 01:00 PM
Porschenut's Avatar
Your old set of tires sounds like a great excuse for a nice long road trip on interstate highways. Maybe visit us up here in Canada! After exchange, your US$ dollar goes quite far here.
EDIT: shoot, I see that you're in the U.K. There goes my idea. I assumed that you were American.
Porschenut is offline
post #10 of 16 Old 03-31-2017, 02:55 PM
banzai's Avatar
When I drop $150 for a track day I want my bike to have fresh new tires. There is a DOT 4 digit oval stamp on the sidewall that tells you the week (first two digits) and the year (last two digits) the tires were manufactured. For instance 4512 would means the 45 week of 2012 (see picture). Because of the supply chain and transit times most tires at best will be 9-10 months old when you buy them. On the track you presumably will be pushing the bike and your skills to the limit. Why handicap yourself or set yourself up for an accident by using old hard rubber at the track.
'04 Blue ZX-10R, FORKS: Race Tech Gold Valves, .85 KG/mm springs, US1 suspension fluid, Shock: Penske 8900 shock w/8760 compression adjuster, Gilles rear sets and levers, Scotts steering damper, Racefit Mega slip on, Zero Gravity screen, ZX636 Master Cylinder, Galfer Superbike braided brake lines, Vesrah SRJL17 pads, Kawasaki seat cowl, undertail kit, Oury Grips, Valentine One radar detector with Legal Speeding heads-up helmet LED.
banzai is offline
