Gen4 rear link conversion - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 19 Old 08-16-2016, 03:41 AM
Jollygreen's Avatar
Originally Posted by Porschenut View Post
My plates and spacers arrived today. Quality stuff! Thanks ukzx10r! I wish I could give the members some feedback but I won't be sourcing a Gen5 shock until my original Gen4 shock starts to go bad.
Cheers
As stated above quality stuff it only took 6 days to arrive to UT from the GB.
Sent from my SM-G930T using Tapatalk
Jollygreen is offline
post #12 of 19 Old 08-16-2016, 05:15 AM Thread Starter
Glad you like them. Why dont you try them with the standard shock. They will fit
ukzx10r is offline
post #13 of 19 Old 08-16-2016, 02:22 PM
Porschenut's Avatar
There's an interesting idea. What changes would one notice after changing the links but keeping the Gen4 shock? Will the ride height remain the same?
Porschenut is offline
post #14 of 19 Old 08-16-2016, 03:08 PM
Jollygreen's Avatar
It changes ride height.
post #15 of 19 Old 08-16-2016, 04:28 PM
Porschenut's Avatar
I'm currently running 6mm of shims on my Gen4 shock. Would I have to add or remove shims to maintain my current ride height? By how much?
I'm hoping to do as little trial and error as possible as I remember that shimming the shock was a small pain in the neck. Thanks!
post #16 of 19 Old 08-16-2016, 04:46 PM Thread Starter
These links add 2mm with gen4 shock and nothing with gen5 as they were designed to use the gen5. But 2mm is not really noticable.
The difference is with the ratio and how it will work the shock faster.
I believe it will work great as it will try move the shock faster which will make the damping work better. The standard plates are too slow to feel much damping at all.
The only thing i would suggest is if your a light person you may want to unwind the preload a bit so you can keep your sag somewhere near where it was with the standard plates.
If your on the hevier side then they will work better for you.
ukzx10r is offline
post #17 of 19 Old 07-04-2017, 11:29 AM
mpp12's Avatar
price to miami 33126
thanks
mpp12 is offline
post #18 of 19 Old 07-10-2017, 05:23 AM Thread Starter
thanks
Sorry i will sort a price out for you. Ive just been so busy recently i havnt had time to see if i got a set ready to post
ukzx10r is offline
post #19 of 19 Old 07-11-2017, 04:23 PM
Krystian_Lobodziec's Avatar
I received mines last week and must say they are very good quality.
Today shock arrived now only need to find spare couple of hours to swap old for new one! This week working 7 days for minium 12h each day 😑
Wysłane z mojego EVA-L09 przy użyciu Tapatalka
Krystian_Lobodziec is offline
