Gen 5: 2016 -> Gen 4 front wheel to Gen 5 kit - Page 2 - Kawasaki ZX-10R.net
post #11 of 26 Old 05-13-2016, 07:58 PM
Name:	ImageUploadedByMO Free1463187382.649379.jpg
ID:	372785Click image for larger version
Name:	ImageUploadedByMO Free1463187394.970372.jpg
Very lightweight aluminum. I can not express how perfect the fit is. Zero space. Very happy. Took about 7 business days to get to Kentucky. Spacing fit etc is perfect. I have attached a few pictures of them on my wheel
gsxrvette is offline
post #12 of 26 Old 05-13-2016, 08:11 PM
tdh
tdh's Avatar
The only thing that bugs me a bit is that the rotors themselves are not fit over the wheel hub grooves and only the bolts are holding the rotor from moving. That's probably not a huge deal. To be honest I leave a set of rains mounted on my spare set so I don't use them often and would only use them in a rain race. I guess bottom line is I'll take a set of spacers. :) The rear wheel is the same correct? EDIT: I also just remembered I'll need to get a set of rotors as well, or move the rotors over from my other wheel if I need to swap them.
tdh is offline
post #13 of 26 Old 05-13-2016, 08:25 PM
The left side on the front hits the hub. The ribs from the hub don't stick far enough out on the right so it is on the spacer.
post #14 of 26 Old 05-13-2016, 09:05 PM
tdh
tdh's Avatar
I'm not sure I understand what you are saying.
tdh is offline
post #15 of 26 Old 05-13-2016, 09:58 PM Thread Starter
fireman69's Avatar
The left side has a deeper shoulder due to the TC ring. It still centers the rotor even with the ring.
The right side is centered with the rotor bolts. I believe that is what he was trying to say.
I just installed a set onto a wheel today as well. These are a perfect fit. They saved me from having to buy 2016 wheels for the new racebike.
fireman69 is offline
post #16 of 26 Old 05-13-2016, 10:05 PM
tdh
tdh's Avatar
That makes sense. What about bolt length? There would be fewer threads in the hub.
tdh is offline
post #17 of 26 Old 05-14-2016, 05:37 AM
That part is true. I would have to measure how much bolt goes into the wheel but it is at least an inch.
post #18 of 26 Old 05-14-2016, 09:03 PM Thread Starter
fireman69's Avatar
There are more than enough threads to pass through the wheel into the hollow of the rim. Not a issue.
post #19 of 26 Old 05-24-2016, 09:21 PM Thread Starter
fireman69's Avatar
To the top.
post #20 of 26 Old 07-18-2017, 06:02 PM Thread Starter
fireman69's Avatar
Apparently there are a few more spacer kits available. Contact will for more information.
