Gen 5: 2016 -> Zx6r not doing it for me... - Page 5 - Kawasaki ZX-10R.net
 31Likes
post #41 of 52 Old 11-08-2017, 09:46 AM
Capncalyx's Avatar
^^^^^^^^^^^^^ Thats how ive done it for years.
I keep a cheapo notebook with info in it like torque #'s, different mileages and pages of suspension adjustments. I Star* or highlight in some way the ones that feel good or the direction that feels good and keep going in that direction until it doesnt feel good and go back one. Do one adjustment at a time too like either rebound or comp or spring but dont mix em up until you really get a feel for what you're doing. At first it took me a while to learn what i was feeling and how to feel it and it was frustrating the first couple years. But after riding, adjusting in small amounts and repeating, about the 2nd or 3rd year it really started to click with me, ya that long lol. Now i feel im at a place where i can make adjustments with confidence knowing about what effect it should produce and have gotten to where its at least something i can work with on the street until i can get better suspension parts. Im not saying im a expert by any means - far from it, this is just how i do it.
Although i will say its an ongoing thing, i still tweak it here and there and try to fiddle with it to see if i can get it better but with stock suspensions its usually a pretty fine line. If i screw it up and it gets out of whack, i go back to my Star'ed* settings i liked that i have written down. And if you change tires or psi you may need or want a small adjustment.
I always try to shoot for a balance between what the back and front are doing. Dont want em fighting with each other. If the back rebounds fast i try to match the front with it. I like the rebound to be pretty fast with nice compression and i use a zip tie or whatever on a fork to see how much comp im getting and i adjust so at the hardest bump in my ride i still have and inch or so left on the fork for any emergency dive/bottom out. Its not easy to do on your own but i usually push down on the rear somehow and the front to note how fast the rebound seems - you get a better idea once you ride though.
I really wish more people wouldnt be so afraid to mess with their suspension, it can be fun and you can dial yourself in to different rides or road conditions if you know what you're doing well enough. Also ive found that there's a fine line on the adjusters too. For example i like a lot of compression but there's only a small area of adjustment where i can get what i want but if i go too far either way, and its not much, it either gets super hard or so wacky soft it feels unstable. Dont go far, just a click or millimeter or quarter turn, whatever.
You might even try to find a tire that will absorb the bumps a little better... see? There are little tricks to try yet. Sorry for the book.
NinjaLife likes this.
*Official winner of one Riflemans 1/5 insert
"Stop being such a Sheila, Peter" - Peter's Dad
Capncalyx is offline
post #42 of 52 Old 11-08-2017, 02:35 PM Thread Starter
As obijack mentioned, 2wdw provides mail in flash options. you tell em what mods you have, they put the flash in for those mods. each flash is developed on the dyno with each mod, so it's a match to your bike
edit: they should be running a black friday sale soon around $300 or less for the flash FYI
and after reading your last post, the suspension issue, that's a tricky one since your street surfaces are less than ideal, you'll wanna soften up the suspension a few clicks. basically, get a piece of paper, and write down your current settings. to do that, you take a screwdriver/socket whatever adjustability you have and screw it all the way in, counting exactly how many full turns it takes to bottom out, if it goes down and is only a 1/2 or 3/4 turn, you write that down. then, count out all the turns to fully out. now you know your range, and where you were. so, set it back to where it was, then turn it out, lets say 2 times. write it down. now, go ride, write down comments about its changes. good/bad whatever, then adjust some more. be sure to write it down.
if that all sounds like too much, then just start with "turned out compression 2 full turns" instead. you won't know your starting point, but if you write down each change you make, you can at least get back to where you were if it's worse.
your sag/rebound settings are easiest to be done by a suspension tuner, its usually $30 or so, takes 5 minutes, and is just easier than doing it yourself since you'll need a buddy there to help you. however if the shop says its set for you, either take em at their word, or spend the coupla bucks making sure it's set properly. i know seasons bad for it but if you ever go to a trackday, there's almost always a suspension tuner there who knocks out setups like that cheaply.
Great advice on the suspension tweaks. Thanks! On the subject of the ECU flash, is the cost of the ECU flash any more expensive if it is a ZX10R and does the gen version matter? Just curious.
cmbnyc is offline
post #43 of 52 Old 11-08-2017, 02:38 PM Thread Starter
More great advice and feedback on suspension. Thanks!
cmbnyc is offline
post #44 of 52 Old 11-08-2017, 02:50 PM
nakedinseattle's Avatar
Cost is same for whatever gen ZX6R or ZX10R, doesn't change on those models or by year.
cmbnyc likes this.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #45 of 52 Old 11-08-2017, 02:50 PM Thread Starter
So yesterday I went to a dealer (not my usual one) not too far away that had a 2016 ZX10R, 2017 Z900 and my own 2016 ZX6R.
For the hell of it I sat on all three bikes a few times in a specific order, Z900 > ZX10R > ZX6R rinse and repeat. The salesperson held the bikes upright for me so I could get a more realistic idea of how they felt as opposed to sitting on them on the kickstand.
The Z900 felt super comfy and looked pretty mean, but the lack of any real wind protection might bother me especially since I ride through the cold NYC winters when the road conditions are reasonably safe.
The ZX6R felt like my current bike. Duh! So that was no surprise.
The ZX10R actually felt more comfortable than the ZX6R in terms of the reach to the bars and how my legs wrapped around the tank. The seat height is higher and the pegs may actually be higher so in a way I was more in a bunched up seating position than on my ZX6R, but it just felt more comfortable and I didn't feel like I was hunched over as much or angled downward toward the tank.
Go figure.
I've still got a great deal on a leftover 2016 ZX10R with either ABS or non-ABS in black about 2.5 hours away and just confirmed with one of my friends that he can go take me up using his large van to get the ZX10R and trade in the ZX6R if I choose do it.
Decisions, decisions, decisions.
cmbnyc is offline
post #46 of 52 Old 11-08-2017, 07:15 PM
Adjusting Motorcycle Suspension
Give this a read, it's actually a pretty good article on beginner suspension tweaking, explanations and how to's.
cmbnyc likes this.
Shut up and ride.
post #47 of 52 Old 11-19-2017, 01:25 PM Thread Starter
Thanks nakedinseattle :)
cmbnyc is offline
post #48 of 52 Old 11-19-2017, 01:28 PM Thread Starter
Are there any reasonably priced, quality rearsets out there for the 2016 ZX10R that would lower the pegs a bit for more legroom comfort? When I sat on the 2016 model in a local showroom, I didn't mind the higher seat so much compared to the gen 4, but the pegs felt too high for longer rides.
cmbnyc is offline
post #49 of 52 Old 11-23-2017, 10:09 AM Thread Starter
Well just a little update. I've ridden the ZX6R a few more times and have come to the conclusion it is not worth losing so much money on trading it in for a new ZX10R even though I found a killer deal on a 2016 leftover model about a 3 hour drive from me. The trade-in offers from dealers for the 2016 ZX6R is horrendous due to the rebates and discounts Kawasaki is offering on brand new models. I still owe about 6700 on the bike and the best most dealers can give me is to just pay off the loan outright and take the bike. I could do much better selling it privately once I pay off the loan myself which should happen in the next few months.
So, for now, I'm going to try living with the ZX6R and making some tweaks here and there to improve the comfort factor. To be honest, it is really a great bike but I kind of got spoiled by having owned two GSXR 750's before which were almost like Goldwings in terms of comfort and soaking up bumps.
A guy on the ZX6R forum recommended SpeedyMoto Omni Bars to help with the reach to the bars comfort issue: https://www.speedymoto.com/products/...ars/omni-bars/ He stated that the really clever aspect of the Omni Bars are the bars specifically. They are bent 14⁰ - which doesn't sound like much, but effectively creates a cam-effect. Also an aftermarket seat such as the Saddlemen Track-CF Style Gel Channel Solo Seat may help a lot. Lastly an ECU flash will be in order to smooth out the on/off throttle abruptness and maybe give it a bit more power.
This may be all from me for now. I really appreciate all the feedback I've received from everyone on this forum. Hope all of you stay safe and have fun riding your ZX10R's and remember to secure your backpack zippers or any gear you may have while riding!!! LOL
cmbnyc is offline
post #50 of 52 Old 12-06-2017, 09:26 PM Thread Starter
Well, I picked a 2013 GSX-R750 in excellent condition with low miles yesterday after trading in my ZX6R. Before loading the Gixxer up in my friend's van I took it for a quick test ride and it fit me like a glove. The ergonomics are great, the sound of the engine induction is wonderful and the power is much better than the K4 and K7 models I previously owned. Seems like the handling is better as well, but time will tell on that point. Dropped the bike off at my local Suzuki/Kawasaki dealer who I trust and know well and will have the oil changed, everything checked out, an M4 slip-on installed and a better fender eliminator added. Just need to choose an aftermarket double-bubble screen.
I still think both the ZX10R and ZX6R are great bikes without a doubt. If my Gen 4 ZX10R hadn't been totaled I'm sure I would have been very happy with it. The ZX6R would have worked great for me if the ergonomics were different. I sincerely tried to live with it and adjust to it for a couple of weeks, but it just wasn't happening.
I appreciate all the feedback and great advice from all who posted on this thread. I still have my 2001 ZRX1200R so half of me still bleeds Kawasaki Green. LOL
Name:	IMG_2915 (Large).JPG
ID:	408105   Click image for larger version
Name:	IMG_2919 (Large).JPG
ID:	408113   Click image for larger version
Name:	IMG_2917 (Large).JPG
cmbnyc is offline
