Gen 5: 2016 -> ZX10RR Superstock racebuild!! - Page 5 - Kawasaki ZX-10R.net
 67Likes
post #41 of 176 Old 04-05-2017, 10:08 AM
theatiss's Avatar
Originally Posted by Newf View Post
Also, anyone that was planning to just use some of the zx10rr parts in there zx10r, the tappets alone are 2000euro/set, wheels are 4300euro and they're not actually light weight wheels. Weighed the rear compared to my BMW OZ racing and 2kg+ heavier, so doubt they're much if any Lighter than std zx10r.
And whats the weight of your oz racing rear wheel?
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #42 of 176 Old 04-05-2017, 10:55 AM Thread Starter
Newf's Avatar
11.9kg vs 14.1kg with Superbike slicks and no sprocket carrier. Weights might be a little off as I wasn't using a proper hanging weight scale but the rim is noticeably heavier.
theatiss likes this.
Newf is offline
post #43 of 176 Old 04-05-2017, 01:11 PM
Great updates!
On the steering damper, websites call for an SD 021, but the kit manual calls for an SD 001. It has 3mm more stroke. One of the parts to mount an SD 001 (collar) is no longer in production, but I've a spare if anyone needs it.
Really interesting about the wheels. As far as the pistons and crank goes, were you able to verify that the pistons are higher compression? I'm really curious about the differences. I'm wondering also if the crank was modified for the crankcase, or if it was made stronger / lighter in key areas.
So many questions!!
HowLongYourUserNameCanBe. is offline
post #44 of 176 Old 04-05-2017, 01:32 PM
dricked's Avatar
Originally Posted by HowLongYourUserNameCanBe. View Post
Great updates!
So many questions!!
Compression ratio is the same. I was told they are lighter but don't have exact measurements. Aside from that there's no difference for the pistons.
Glad I didn't spring for the RR wheels!
Newf likes this.
dricked is offline
post #45 of 176 Old 04-05-2017, 01:39 PM
Duhastme's Avatar
That is strange! In another thread one of our other forum members was stating that the wheels were specially made for the RR to specifically be lighter then the production wheels carrozzeria makes. I wonder what / if if there is a difference
Duhastme is offline
post #46 of 176 Old 04-05-2017, 02:58 PM
peterd10r's Avatar
Images: 7
That's a lot of weight more to be spinning compared to your Oz rims!I heard the same thing as Duhastme about the rims on the RR being lightweight but can't remember who from!what did you use to weigh them did you say a hanging type scale?luv the thread always interested in members developments from shop to track cheers man
peterd10r is offline
post #47 of 176 Old 04-05-2017, 08:16 PM Thread Starter
Newf's Avatar
I've read the same post that they were 1lb lighter than the aftermarket light weight wheels but think it's actually 1lb lighter than standard zx10r. It's doesn't actually say in that they they are suppose to be lighter it's just says lighter turning and lower moment or inertia...lol. Just used a floor scale so could be off a little but they're noticeably heavier just lifting.
Name:	ImageUploadedByMO Free1491441330.674280.jpg
Duhastme likes this.
Newf is offline
post #48 of 176 Old 04-05-2017, 08:19 PM Thread Starter
Newf's Avatar
Thai race mechanics said the same that the pistons are lighter but look the same.
Also noticed front master cylinder and brake calipers are different part # to zx10r.
Newf is offline
post #49 of 176 Old 04-06-2017, 11:11 AM
dricked's Avatar
Hmm, no mention of different brakes anywhere. I'll have a good comparison between the two this week. Going testing and one of the guys is on a new RR, was on a regular 10r last year.
dricked is offline
post #50 of 176 Old 04-06-2017, 08:36 PM Thread Starter
Newf's Avatar
The thai Kawasaki riders here have been racing the bike since Jan. One rider said the engine does feel stronger stock and the top speeds were a little higher back in Jan when they first raced the bike. But I've heard one of the top British Superstock riders tested them back to back and couldn't notice any difference.
Newf is offline
