Gen 5: 2016 -> ZX10RR Superstock racebuild!! - Page 14 - Kawasaki ZX-10R.net
 67Likes
post #131 of 176 Old 12-01-2017, 05:12 PM
Really fun to read about your build and progress.
What brand of fairings are you using? That tank cover looks really good.
Lanes is offline
post #132 of 176 Old 12-01-2017, 05:19 PM Thread Starter
Newf's Avatar
Originally Posted by evallarta1 View Post
Have you tried adding some bypass to the shock? On the standard piston some of our fast guys are running with the bypass 2 to 3 clicks out to control the movement.
Hows you're preload on the front? It's not unusual for us to run 12 to 16 turns of preload with a softer spring. This gives you more braking support and better midcorner feel. With the stiffer topout spring in the K-Tech they want more preload and work 1000% better.
We generally wont go any higher than 190 on the oil level, usually we're floating around the 200ish mark.
I've tried different bypass settings but i find the best setting is either fully closed or middle 8 clicks.
I run between 6-8 turns of preload on the front with the 10.5/11, i did start off with 10.5/10.5 and i was using 12-14turns but at that time i had a better feeling with the harder spring and less preload. I haven't tested more airgap on my current forks just a friends but it is something i plan to try if i can get some testing time in.
Now that i have a base setup that i know i can always go back to for raceday i will experimenet more with different spring rates & airgaps. The practice seesion during the race weekend are very short at 15min and you really only get to try one setup per session, so most of the actual testing needs to be done on open trackdays. Problem is is theyre hasn't been many open trackdays that have been dry this year so its always been a rush to find the right setup.
Newf is offline
post #133 of 176 Old 12-01-2017, 05:22 PM Thread Starter
Newf's Avatar
Originally Posted by mpp12 View Post
that fine dust does not pass in the MRW...
Yes, my airbox was clean after running the MWR and i plan to continue using it instead of the P16.
Newf is offline
post #134 of 176 Old 12-01-2017, 05:23 PM Thread Starter
Newf's Avatar
The fairings are a Thai copy of CRC.. at a dicounted price...!!!
Newf is offline
post #135 of 176 Old 12-03-2017, 11:37 AM
NEWF.... Just read front to back your posts.. Incredible! Great to see you living the dream!.. In the beginning of your post, I noticed your exhaust hanger during your build pics... Who makes that unit??
Thank you.
RC
RC51-05 is offline
post #136 of 176 Old 12-03-2017, 05:11 PM Thread Starter
Newf's Avatar
Thank you.
RC
Itís the stock Exhaust hanger on the zx10rr
Newf is offline
post #137 of 176 Old 01-06-2018, 07:26 PM Thread Starter
Newf's Avatar
Ready to do some test/tuning on the zx10rr and s1000rr the next 2 days. Installed o2 bungs on cylinder 1 & 2 so I can make separate maps in the race ecu and will also test e85 in both bikes. No dyno runs just on track datalogging... testing at BIRA circuit which is a small track with 240km/hr top speed so not a full tune for top end but should save me a little time in 2 weeks when I race at Chang international!!!
Sebastian1000 and ddipaola like this.
Newf is offline
post #138 of 176 Old 01-07-2018, 09:40 AM
moto316's Avatar
Does your chrome dash accept multiple o2 sensors? Also did your headers come with bungs in each head pipe or is that something you had added? I ordered a chrome plus as well, interested to hear your feedback on the tuning process for A/F ratio, etc. I'm hoping mine will help dialing in the off/on throttle transition and smoothening out the power delivery coming off corners.
moto316 is offline
post #139 of 176 Old 01-07-2018, 10:16 AM Thread Starter
Newf's Avatar
Iím just using the Lambda that comes with the chrome plus and I have an LC-2 that I just connected to one of the other analog ports. But having some issues with the LC-2 as it keeps cutting out after about 2 laps, was doing the same when I had it on the s1000rr, thought it was just a loose connection but guess not.
I had a o2 Bung welded onto cylinder 1&2 at a local welding shop, With the map that I had made on the dyno cylinder 2 seems to be fairly smooth but cylinder 1 jumps around a lot more and will need more time to tune properly.
Newf is offline
post #140 of 176 Old 01-07-2018, 10:19 AM
moto316's Avatar
Is there a reasoning behind only tuning cyl 1&2 and not 3&4 as well?
moto316 is offline
