Gen 5: 2016 -> ZX10RR Dyno result - Page 2 - Kawasaki ZX-10R.net
 9Likes
post #11 of 21 Old 01-21-2018, 10:57 PM
EvokedPotential's Avatar
Beastly but meaningless without something to compare it to
EvokedPotential is offline
post #12 of 21 Old 01-22-2018, 10:23 AM
Schooley's Avatar
THIS.
The fact that the OP only posted final numbers and in STD says a lot.
Schooley is online now
post #13 of 21 Old 01-25-2018, 07:32 PM
BAKWHEELTANGO's Avatar
hey guys,
I just got back from 2wheeldynoworks.com yesterday - here's my graph...
Stock 2016 Kawasaki Zx10r vs. Graves low mount cat delete slipon and custom ECU flash by 2 Wheel Dynoworks. 41 Horsepower gain! (at the vertical bar)
lun471k likes this.
BAKWHEELTANGO is offline
post #14 of 21 Old 01-25-2018, 07:33 PM
Post Whore
Older Guy's Avatar
Huge increase.
Older Guy is offline
post #15 of 21 Old 01-25-2018, 08:38 PM
Victors's Avatar
Originally Posted by BAKWHEELTANGO View Post
hey guys,
Just fueling changes?
2013 10R
2007 650R
2016 10R
Victors is offline
post #16 of 21 Old 01-26-2018, 07:42 AM
gaz
great tune from dyno works, afr spot on, also torque more realistic at 81 ft lbs and peak power extended over 1500 rpms.
gaz is offline
post #17 of 21 Old 01-26-2018, 09:29 AM
Well since we are whipping out our wee-wees here:
Run 2: 100% stock
Run 21: Fitted Akra Evo /w removed baffle, custom ETV map and custom timing map - no fuel changes
All done same day
Name:	Screenshot 2018-01-26 00.26.14.jpg
Victors, lun471k, Schooley and 1 others like this.
ZX10RArcher is offline
post #18 of 21 Old 01-26-2018, 12:51 PM
lun471k's Avatar
hey guys,
Thank for that. I guess I can expect similar numbers from my 2WDW reflash & tune with my m4 GP.
BAKWHEELTANGO likes this.
lun471k is offline
post #19 of 21 Old 01-26-2018, 01:57 PM
Juh@'s Avatar
Did a custom map on my ZX10R 2016 with cat delete and a BIG Arrow slipon (problems with noise regulations). This run I had about 193, the lower numbers are from a 2016 R1 with same modifications, it´s about 10 less. My 2011 had also about 183 on the same dyno.
Name:	zx10r 2016 mapping.jpg
lun471k likes this.
Juh@ is offline
post #20 of 21 Old 01-26-2018, 02:46 PM
Schooley's Avatar
Run 2: 100% stock
All done same day
Attachment 411361
Your wee-wee is biggest, considering you're actually using SAE numbers.
