Gen 1: 2004-2005 ZX10r build/revamp - Kawasaki ZX-10R.net
 12Likes
post #1 of 86 Old 04-18-2015, 05:07 PM Thread Starter
Tweezy's Avatar
ZX10r build/revamp
Ok, I traded my custom CBR929 for a Clean title 16,000mi 04 ZX10r.
Looks to have been a track bike at one point but got turned into a Drag bike. Then downed on the left side but not bad, broke the foot peg and heel plate on the rearsets. Also bent the lever a little and the under belly is no where to be found....
On the plus side it came with a 19x20 Brembo M/C, steel braided lines, no stretch R k 525 chain, a GPR stabilizer and a full set of after market fairing, brand new! Oh, plus the motor runs great!
On the bad side, it had been stretched and lowered... Also they had also ground off 2 of the mounting point off the subframe for the tail, no headlight and the plug for the headlight was cut off. I just couldn't cut the plug off the headlight, to splice it into the old harness. Oh, there's a some fleebay style Gp pipe on there and the squid I got it from put a few small dents my headers, getting off his flat bed... He high sided it right on the headers, over and over... I was like please stop but the damage had all read been done.
So, I order a headlight, integrated taillight, turn signals, Gold Vortext rear sets, Brembo mono-block m4 Brake calipers, ZX14/new zx10r Glafer brake rotors, a normal length rear steel braded brake line, new subframe, Headlight wiring harnessed, vortex pressure switch for rear brake, rear trunk lock and cable, solo seat cowl hump thingy, Rear seat truck latch, Ram air ducked intake grill, I'm sure there's some other stuff in there like nuts and bolts etc and I may throw some HID's or LED's one there. I have some on hand but don't wanna cut wires, at all! Oh and all be getting a full exhaust here soon. Plus, a Bazzaz fi TC with the switch to flip between 10 levels of TC on the fly!
ID:	319625   Click image for larger version
ID:	319633   Click image for larger version
Tweezy is offline
post #2 of 86 Old 04-18-2015, 05:27 PM
TrickKwak's Avatar
Look forward to seeing the transformation.
Keep us posted!
2005 ZX-10r
TrickKwak is offline
post #3 of 86 Old 04-18-2015, 06:21 PM
Matteson's Avatar
Did you check the frame for cracks since it was wrecked?
Matteson is offline
post #4 of 86 Old 04-18-2015, 11:55 PM Thread Starter
Tweezy's Avatar
Well, I took off the swingarm extension and the dog bone to rear stock too. I also raised the front back to stock, took off the old and mounted the new subframe, broke the chain to fit the OEM swingarm, Changed the rearsets to my gold vortex rear sets, put on the tail and the integrated taillight. mounted the brembo's for a min then took them off because they set 5mm to high and I don't wanna roll my cbr1000r rotor and a spacer. It's only be a few days till my Galfer wave rotors will be here.
ID:	319737   Click image for larger version
ID:	319745   Click image for larger version
Tweezy is offline
post #5 of 86 Old 04-19-2015, 12:05 AM Thread Starter
Tweezy's Avatar
A few more pic's. How do you put more then 3 picture's per page???
ID:	319761   Click image for larger version
ID:	319769   Click image for larger version
Tweezy is offline
post #6 of 86 Old 04-19-2015, 12:11 AM
U.S. Marine Corps Veteran
I2aMpAnT's Avatar
Send a message via Skype™ to I2aMpAnT
Great work thus far!
I like to post them on Facebook and then post them with URL tags.
Facebook.com/I2aMpAnT
YouTube.com/I2aMpAnT
USMC
I2aMpAnT is offline
post #7 of 86 Old 04-19-2015, 04:14 AM
or10r's Avatar
Thats a great start man. She is going to be nice.
or10r is offline
post #8 of 86 Old 04-19-2015, 04:55 AM Thread Starter
Tweezy's Avatar
Thanks brother, I've got more pic's but I'm not sure I wanna post them all over facebook... Pic's of the reasons I replaced parts, thought about doing a step by step on everything I'm doing. How to splice wire's "the right way" not just twisting them together and taping them up, put on rearsets and pressure bolt, Raise or lower your bike, my brake swap etc.
Some pic's of the subframe I took off and why. it had been modded to fit a zx10r race tail and yes I'm most likely keeping it for race weekends, more then likely this will become my race bike at some point! Oh, plus the broken heel plate and peg!
ID:	319809   Click image for larger version
ID:	319817   Click image for larger version
Tweezy is offline
post #9 of 86 Old 04-19-2015, 05:05 AM Thread Starter
Tweezy's Avatar
And after
ID:	319833   Click image for larger version
ID:	319841   Click image for larger version
Tweezy is offline
post #10 of 86 Old 04-19-2015, 07:06 PM
I2aMpAnT's Avatar
I believe you can make the album private on Facebook and the URLs to the direct image should still work.
USMC
I2aMpAnT is offline
