Gen 4: 2011-2015 Zx-10r Sprocket question - Kawasaki ZX-10R.net
 6Likes
  • 1 Post By LDH
  • 1 Post By Carlos76
  • 2 Post By LDH
post #1 of 10 Old 01-08-2018, 01:36 PM Thread Starter
Hello folks
So i use my gen4 lately just on my local track which is pretty small and can be considered a "go-kart track"
the bike is currently geared @ 17/47, pretty good for the track but i wish there was abit more low end torque
would 17/49 damage the bike in any way ? Most liter bikes use first, second and third gear only on this track since its quite small with lots of tight corners
so ye my main question here is actually if too big of a sprocket setup could hurt the bike (don't care about chain wear and sprocket since i change those out often)
wowjudo is offline
post #2 of 10 Old 01-08-2018, 01:42 PM
LDH
LDH's Avatar
Just put a 16T on the front...
wowjudo likes this.
LDH is offline
post #3 of 10 Old 01-08-2018, 02:09 PM
Carlos76's Avatar
Vortex makes 15T for oem 525 chain. Try 15/47, it may help use 1st gear less.
wowjudo likes this.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #4 of 10 Old 01-08-2018, 04:23 PM Thread Starter
sounds interesting
is there a difference actually by changing front vs rear ? i know that -1 front equals around +3 in the rear but i also heard that going down front gives better lowend torque while upping rear gives better mid/high torque. not sure if it's true
wowjudo is offline
post #5 of 10 Old 01-08-2018, 04:36 PM
Victors's Avatar
Originally Posted by wowjudo View Post
sounds interesting
Anytime you can take weight off the driveline youre better off. Going down a size in the front would be better. Going up in the rear adds size and weight...
2013 10R
2007 650R
2016 10R
Victors is offline
post #6 of 10 Old 01-08-2018, 04:54 PM
The Pace
scout's Avatar
Try this sprocket calculator:
Sprocket Calculator - the easy motorcycle sprocket and chain calculator
You will see what 17 and rear matches 16 and rear.
scout is online now
post #7 of 10 Old 01-08-2018, 06:53 PM
Carlos76's Avatar
I'm not aware of such theory.
In practice "final drive ratio" (R divided by F) is what affects torque, rpms, speed.
Sprocket changes affect a bit handling of the bike too (wheelbase and swingarm squat).
thundercoupe9 likes this.
Carlos76 is offline
post #8 of 10 Old 01-08-2018, 07:23 PM
LDH
LDH's Avatar
I was totally not going to go there, but I am amused you did
Anyone that has to post up questions on a forum about final drive gearing already has no understanding of acceleration rate vs elapsed time nor the mathematics that derive hp and torque let alone gyroscopic precession or the swingarm downslope augmentation by changing the angle from the CS to the Rear Sprocket. For a fleeting moment I almost posted up an addendum (no pun intended) to my original post, but thought better of it. I'm only posting this now because I am imbibing Bombay Sapphire and the whole thing made me giggle a bit. Obviously alcohol killed the weakest brain cells I had and made me smarter for a few minutes.
Now here is a pic of my cat El Bandito
Carlos76 and Helitech like this.
LDH is offline
post #9 of 10 Old 01-08-2018, 08:51 PM
thundercoupe9's Avatar
sounds interesting
It's a gear ratio, not magic.
thundercoupe9 is offline
post #10 of 10 Old 01-09-2018, 10:09 AM
Carlos76's Avatar
That young man may figure it out and test on track.
Our and ElBandido's old brains and bladders run on autopilot anyway.
LDH likes this.
Carlos76 is offline
