ZX-10R KRT vs ZX-10RR - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Newf
post #1 of 10 Old 09-04-2017, 03:26 PM Thread Starter
Hi Guys,
Does anyone knows the exact differences between the 2017 zx-10R krt and 2017 zx-10RR besides the marchesini wheels, 24 degrees on krt, 23.5 on RR and stock up/down feature on RR?
I mean, if we install the race harness & ecu & camshafts, are there any real differences?
I'm really curious to find out.
Thx!
morpheusro is offline
post #2 of 10 Old 09-04-2017, 03:31 PM
Victors's Avatar
Lifters, reinforced block and a few other engine changes for durability and strength
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 10 Old 09-04-2017, 05:40 PM
dricked's Avatar
You can run both kit cams in the RR as well. Personally, building a race bike I'd have a hard time paying the extra for the RR and the added expense of getting spare RR wheels. With the kit ecu/harness you can access all the same features.
dricked is offline
post #4 of 10 Old 09-04-2017, 06:24 PM
RR is $$$$ so if you're on a budget, it may not be worth it, but if funds are not a concern, RR will make a faster and more reliable kit.
JayBoCC2 is offline
post #5 of 10 Old 09-05-2017, 12:45 AM
Newf's Avatar
Originally Posted by morpheusro View Post
Hi Guys,
Thx!
Stock vs stock there's no real difference other then the autoblipper. The rims look alright but same weight as std R and pricey to replace.
With a flashed R you'll have the same power as the RR and also autoblipper, so to be honest if I had known the wheels were so heavy I would have never paid the extra for the RR.
The RR gives the option to run higher lift cams that's about it but if u have no plan to modify the engine then the RR is pointless.
Lanister likes this.
Newf is offline
post #6 of 10 Old 09-05-2017, 06:19 AM
Dhampton's Avatar
Thanks for the Post
Dhampton is offline
post #7 of 10 Old 09-11-2017, 04:43 AM Thread Starter
Thank you guys!
I assume the standard engine runs in race mode for 10.000KM before rebuild? And RR engine maybe a little more?
Any ideas?
post #8 of 10 Old 09-11-2017, 04:45 AM Thread Starter
What do you mean by higher lift cams? Increase engine speed?
As R is 13.600 but via race ecu should be possible to increase speed. Right?
post #9 of 10 Old 09-11-2017, 09:11 AM
Newf's Avatar
Race kit Camshaft, there's more room in the RR cylinder head to run Camshaft with higher lift (lobe size) 11mm vs 10.5mm on the intake but I'm not sure what the exhaust Camshaft differences are.
Both engines can be run at 14,200rpm with Race ECU.
Newf is offline
post #10 of 10 Old 09-11-2017, 01:37 PM
Thank you guys!
Any ideas?
It depends on how you use it and at what level, what fuel you run, etc. Moto America bikes, they run 3k-4k miles and it's time for a rebuild.
Lanister is offline
