Is Your Gen 1's Frame Cracked?? Read Here !!! - Page 4 - Kawasaki ZX-10R.net
 1Likes
post #31 of 106 Old 01-04-2012, 06:37 PM Thread Starter
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Originally Posted by jake318 View Post
Hellsrazor. My good friend is the chief mechanic at a fairly large trucking company thay hauls dry bulk.( which always run maximum weight of 80k)
the trailers are all aluminum and being they run max weight all the time , they crack and need to be welded frequently . I will ask him to conferm this but if recall correctly he would drill a small hole at each end of the crack so it wouldnt spread...weld crack and grind flat .... Then weld a aluminum plate over the crack with the plate covering roughly 1/2 inch over each end of the crack. I will ask him if he refills the smalls holes at the end of the crack and if you should plate both sides (if it is possible you can get to both sides of frame )
Originally Posted by Johns04ZX10R View Post
My buddy did the same thing to mine. He said drill the ends or the crack will keep running.
You are correct about drilling stress relief holes at the end of each crack.
I already have plans for that before I weld it up.
Now the plates will not work where I have to weld mine,
it would get in the way of the motor mount.
I'm going to invert the frame and weld it down hand to
keep the heat localized.
And I think that should be plenty good enough to hold it.
Hell, if it happens again down the road from me riding it like I stole it,
I'll just weld it up again.
hellsrazor is offline
post #32 of 106 Old 01-07-2012, 07:50 PM
jake318's Avatar
Images: 9
I called friend who welds stress cracks on aluminum dry bulk talks . He said to weld the holes at the ends of cracks . Then grind out the crack itself . Then weld a plate on backside over crack. Next grind plate where crack has be grinded(not through the plate but deep enough for weld to grab ahold of ) then weld both th ground out crack and the plate behind the crack.
If you cant get to the backside of the crack. Drill holes on each side of crack. Refill with weld grind out the rest of the crack- weld and smooth . Then weld plate on top of crack/weld . I hope this helped as my teaching skills are lacking lol.
jake318 is offline
post #33 of 106 Old 01-18-2012, 07:27 PM Thread Starter
hellsrazor's Avatar
Images: 23
OK, I'm welding my frame tomorrow..
Can't wait.
post #34 of 106 Old 01-21-2012, 10:07 AM Thread Starter
hellsrazor's Avatar
Images: 23
Ok everyone, if you have not submitted your information yet, you need to
Because Friday January 27th, all information is being submitted to Kawasaki's USA
and JAPAN.
So, now is the time to act.
post #35 of 106 Old 01-26-2012, 06:34 PM
Hey,I'm new 2 the forum,i have a 04 zx10r with major cracks,2nd owner 12k miles never crashed, I'm tryn 2 join your group on Facebook thru my wifes page
Oh4ten is offline
post #36 of 106 Old 01-26-2012, 06:37 PM
Is it true u have 2 b the original owner n the bike can have no mods???
Oh4ten is offline
post #37 of 106 Old 01-28-2012, 04:00 PM Thread Starter
hellsrazor's Avatar
Images: 23
I will add you if you request it on f/b
Yes it is true. Unfortunate but true.
I am extending the deadline to this Monday.
So that a few more people can join.
Get your names in.
post #38 of 106 Old 02-05-2012, 01:10 PM
OOphLAMEr's Avatar
Send a message via AIM to OOphLAMEr
Some Hope for Those that Bought Used
I'm the second owner of my bike & Kawasaki coughed up a frame. But, they weren't willing to pay for any labor, so I'm doing the whole thing myself.
The dealer said that Kawasaki gave the frame because my bike was super-clean & they wouldn't consider it if there was any sign that the bike was crashed. All that said, the dealer sent photos to their rep at Kawasaki & they got the approval for my frame the next morning.
All Glory to the Hypnotoad!
OOphLAMEr is offline
post #39 of 106 Old 02-06-2012, 08:46 PM
handlecap's Avatar
Where are these cracks showing up? Same place on everyone's or different, just bought a gen1, kinda worried.
handlecap is offline
post #40 of 106 Old 02-06-2012, 08:50 PM
handlecap's Avatar
Disregard.......
