Is Your Gen 1's Frame Cracked?? Read Here !!! - Page 11 - Kawasaki ZX-10R.net
 1Likes
post #101 of 106 Old 10-30-2015, 10:22 AM
Johns04ZX10R's Avatar
soo my brank new frame of last year last only this summer... did about 20-25 day of track and racing and its cracked again.. ill have it weld but does any of you have put reinforcement that lasted?
Make sure you are installing your engine mounting adjuster nuts correctly. If the frame is pinched together or spread apart too much (due to the adjuster nuts), it will put stress on the spars and cause them to crack. Cast aluminum is brittle. If you are interested, you can also have the frame x-rayed, then decide if its good enough to use.
A 1st Gen Ten will eat the hearts of grown men.
Johns04ZX10R is offline
post #102 of 106 Old 11-21-2015, 05:12 PM
My gen1 was cracked too. We did a full strip down and re welded stronger than new. Careful on tightening the engine brackets so they dont stress the frame
ukzx10r is offline
post #103 of 106 Old 11-27-2015, 08:27 PM
Gen 2 Frame Cracks
Hi Gang, First time Kawi owner and found the left upper weld from the longitudinal frame section, weld cracked right down the center. Bought it used but Kawi is sending a new frame to the dealer to install. Should be like a new bike I suppose. It is a 10/06 production 2007 unit.
Thanks for the great information...
mrcarbon is offline
post #104 of 106 Old 11-27-2015, 08:29 PM
Labor is on me, of course...
mrcarbon is offline
post #105 of 106 Old 03-06-2016, 09:44 AM
Must check this now, got me concerned!! Good thread
RDJ46 is offline
post #106 of 106 Old 03-13-2016, 10:09 AM
Mine was cracked on the left side, had it tig welded. Looked about an inch long but after welded the welder said it opened up to be 4 inches. The repair was so good he only burned the paint half inch back on each side, so my paint repair can't even be seen from the side of the bike. I'm in Ohio, the name of the guy is Mark Keegan, he's a know sprint car racer and fab guy building sprint car frames. $40 to repair. The frame had to be bare bones for him.
tak82 is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
