Gen 5: 2016 -> Woolich software update - Kawasaki ZX-10R.net
 24Likes
post #1 of 98 Old 12-15-2016, 08:17 AM Thread Starter
turtle1000's Avatar
I follow woolich in FB and this popped up so figured I'd share
The latest version of the Woolich Racing Tuned software adds a bunch of features for the 2016-2017 ZX10R. Stay tuned for more in the coming releases.
New Features Include:
- Disable Fuel Cut
- Disable PAIR / Air Injection System
- Disable Intake Flap
- Idle Speed
- Intake Flap Opening RPM Map
- Intake Flap Opening Throttle Map
- Injector Balance
- Ignition Dwell
Existing Features
- Features available for Kawasaki ZX10R 2016-2017
- IAP Fuel Maps
- TPS Fuel Maps
- Electronic Throttle Valve Maps
- Ignition Timing Maps
- Autoblipper (no additional cost)
- Race Shift Pattern (no additional cost)
- Fuel Trim Maps
- Adjust RPM Limiters
- Adjust Fan Temperature
- Exhaust Valve Opening Maps
- Disable Top Speed Limiter
- Disable Stock O2 Sensor
- Disable Exhaust Valve
- Woolich Racing AutoTune
- Real Time Engine Data
- Diagnostics: Read and Clear Fault Codes
scotman623 and chiffeee like this.
More cowbell
turtle1000 is offline
post #2 of 98 Old 12-15-2016, 08:58 AM
SkyDork's Avatar
Indeed. Archer posted this:
Originally Posted by ZX10RArcher View Post
Talked to Justin tonight. He has the following figured out and nailed down as of a few hours ago:
Pair valve disable
Disable fuel cut
Injector balance
Ignition dwell
Idle speed
Intake flap removal
Intake flap maps (opening/closing maps)
He will be releasing an interim update in the mean time to get this stuff in there while he continues to continue working on the list of things we have as well as the rider/race aids like TC, wheelie control, etc.
In this thread Gen 5: 2016 -> Dashboard Modes - Kawasaki ZX-10R.net
#WordCrimes
SkyDork is offline
post #3 of 98 Old 12-15-2016, 12:02 PM
NixK7's Avatar
Nice update, i wonder if Disable Intake Flap actually disables it or is just to stop the bike throwing a code when you remove it
NixK7 is offline
post #4 of 98 Old 12-15-2016, 12:21 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
I think it disable it moving....mainly because i see there is a way to map its opening and closing.
It probably also disable the error light.
more info is on the woolich FB page on a thread with people asking and getting answers.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #5 of 98 Old 12-15-2016, 12:34 PM
NixK7's Avatar
Already asked the same question on their FB page, i am guessing you're probably right and it will disable it, which will be handy.
Best thing about this update is finally getting the fuel cut disable, means my auto tune will start to map the IAP properly, and stop trying to richen it up every time i close the throttle and the AFR spikes due to the fuel cut
NixK7 is offline
post #6 of 98 Old 12-15-2016, 01:36 PM
It disables the code so you can chuck it and not worry about it.
Additionally the maps for the opening rate/conditions for the actual flaps have been put in so you have control over them as well if you don't want to disect your bike.
ZX10RArcher is offline
post #7 of 98 Old 12-15-2016, 02:52 PM
NixK7's Avatar
Any chance you can explain what each of the maps actually mean, as i see there is a high and low map for both the % and the RPM
NixK7 is offline
post #8 of 98 Old 12-15-2016, 05:05 PM
scotman623's Avatar
Some great updates!!! Time to send my ECU back to Nels @2wdw.com
2K16/10r likes this.
The track is my HAPPY PLACE!
scotman623 is offline
post #9 of 98 Old 12-15-2016, 05:12 PM
Vonstallin's Avatar
Images: 16
Can we leave the flap in and disable it from opening and closing via a program switch or by making the maps stay open?
Im thinking of getting an auto tune...
woolich make there own brand? or should i get a Bazzaz?
Oh yeah...where should we look to be updated about the new release?
post #10 of 98 Old 12-15-2016, 05:22 PM
2K16/10r's Avatar
They use woolich for their flashes?
2K16/10r is offline
