Gen 5: 2016 -> Woolich Racing ECU flashing products are a go! - Page 57 - Kawasaki ZX-10R.net
 137Likes
post #561 of 580 Old 03-09-2018, 09:17 AM
g-man's Avatar
Originally Posted by SkyDork View Post
The quickshifter is used for both upshift and downshift (if reflashed). If you turn it off through the cluster settings, it doesn't matter which direction since the signal doesn't get to the ECU if the quickshifter is turned off.
"Woolich" doesn't auto blip anything. Their interface gives you access to the software in the ECU, but it's not a "system" that controls that function. That function has always been there in the stock ECU! You just need the Woolich interface to go in and enable that feature that is there and disabled by default.
Well I'll be darned!
I'll turn back on and test.
I may have a problem anyway. When I just do normal street riding with it on, I have a habit of leaving my toe resting on the shifter when I go to first. I did this before, and it starts blipping the throttle almost throwing me off the bike. There must be a mechanical adjustment so it's not engaging, from that little pressure.
My buddies ZX10R does not do this. If not for that, I'd just leave it on.
g-man is offline
post #562 of 580 Old 03-09-2018, 09:23 AM
SkyDork's Avatar
Well there's your problem! Quit doing that!
No, there's no mechanic adjustment on the switch. It's a switch. It's an electronic push-pull switch. The only mechanical adjustment you have for it is the pedal placement up or down. That doesn't affect the function of the switch, it just repositions the shift pedal.
#WordCrimes
SkyDork is offline
post #563 of 580 Old 03-09-2018, 09:46 PM
Gen 5 Now!!
08zx10rny's Avatar
I meant to quote G-Man and not you Skydork.
actually there is a way to adjust in the Woolich software where you enable Auto Blipper function it has a Activation Pressure function. Yours is probably on like a 2 or a 3. I would change it to like a 5 or a 6.
GEN 5!!!
08zx10rny is offline
post #564 of 580 Old 03-12-2018, 12:36 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Originally Posted by ZX10RArcher View Post
1st batch of updates have gone out - much more to come and soon!
So in the first batch of updates is basically the full on race tools kit. This will include:
- Custom written auto blip coding for gear and RPM, as well throttle blip amount and throttle blip duration and sensor adjustments
***This setup Justin has created works LEAPS better than the OEM setup/adjustments - Silky smooth would be a gross understatement
- Custom written QS coding with actual kill times for gear, RPM and TPS and sensor adjustments
- Adjustable Launch Control with several different settings
- Adjustable pit speed limiter (requires Kawi pit limiter harness)
- Engine warm up protocols, think about all the throttle blips you hear at the races (requires Kawi pit limiter harness)
There are various options now with race tools. So you can either get the full on race tools kit which will come with the upgraded sensor.
-OR-
If you want to use the stock OEM sensor (boo) you can buy just the licensing to access the race tools function but use the OEM sensor.
Additionally launch control is now available by itself if you want to have an adjustable launch control instead of preset KLCM1 or KLCM2
Pit speed limiter harness is required for warm up and pit limiter function and is available by itself. This is a new style similar to what we are using on the new CBR1000RR and the new GSXR1000/R. I do not have these yet, but will order some next week once they're released. Additionally all the pit limiter switches now come with a steel mount that you can insert the switch into and then mount it to the pinch bolts on the clutch perch - simply back out one of the bolts and remove it, put the bracket and switch on, put the bolt back through and tighten to proper torque spec. Comes with two different style brackets, one that is at an angle and another that is flat.
Justin is hard at work at all the other upgrades you guys have been asking for so please be patient, we're almost there!
So we can download the updates and have more settings for the launch control, even if we do not have race tools?
Also did you guys make it easier to set the launch control vs. OEM ? I am a little lost on the changes to launch control..
**2 - and pitt warm up is only thru race tools?
**3 - Is there a launch control function for the gen 4?
My current Race bike is the Gen 4 (in Gen 5 clothes) and I have a bazzaz TC/QS/FI with Ghul flash....but I want to flash using Woolich...will I need to go back to OEM spects to flash with woolich?
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #565 of 580 Old 03-12-2018, 04:08 PM Thread Starter
Yes, if you just want more control over launch control, one can just purchase the "2016-2018 Kawasaki ZX10R Launch Control Key" and you'll be able to adjust the launch control through the software. But, for $60 more you can unlock the entire race tools software package and continue use the OEM sensor by purchasing the "2016-2018 Kawasaki ZX10R Race Tools Key Only" so that would be the way to go. You'll get a more refined QS control, better/more smooth auto blip as well as the option to use the engine warm up/pit limiter.
Yes, it's activated via clutch pull in and hold; you basically sit still, with the bike in first, hold the clutch in for a delay set in the software and it activates. At that point you can either use the launch control or simply back off the throttle to accelerate from the stop normally.
Yes, you would need either:
1) "2016-2018 Kawasaki ZX10R Race Tools Key Only"
or
2) "2016-2018 Kawasaki ZX10R Race Tools"
in addition to the "Kawasaki Pit Speed Limiter Harness Type 1" in order to activate pit limiter and/or engine warm up.
Yes, there has been for sometime, 4 or 5 years... maybe more. It is shown on the website as "2011-2015 ZX10R Launch Control Key". This will allow you to use launch control in your 4th gen ECU, but still retain the QS functionality from your Bazzaz setup as you mentioned.
You would likely want to send back to Guhl to be unlocked first. The guy who hacks all of Guhl's ECUs and writes his software for Guhl, Marlin, has made it that if an ECU is attempted to be reflashed with any other software, it then locks the ECU and it has to be sent to Guhl to be reset for which charges may apply. I have seen it personally on an H2 which he was then charged an additional $150-$170 to have it reset on top of what he paid for the original flash. So maybe if it were an older flash from like 2011-2012 you'd be okay to use the ECU unlock utility within the software, but anything more recent than that, I'd play it safe and send it to him to be unlocked first back to the 100% unlocked OEM state, then reflash with the WRT software.
ZX10RArcher is offline
post #566 of 580 Old 03-12-2018, 04:41 PM
Vonstallin's Avatar
Images: 16
or
Ok thanks much. I had it sent to GHUL in March 2012. One of the older flashes that do not have other features unlocked.
Will my Gen 5 flash kit work on the Gen 4 ecu? so that way I buy the bin file , lauch control stuff and the short wire to connect the ecu to flash box?
post #567 of 580 Old 03-12-2018, 09:50 PM Thread Starter
Yep, all the boxes are backwards compatible. You can actually see in the software now what harnesses/boxes are needed per bike:
So while the box itself is backwards compatible, the bike wiring is different, so you would need a complete 3a harness, not just the extension. If you were to buy the Type 3a extension it won't mate up to the main portion of the harness since it would a two pin connector on the 3a versus one pin on the 13a.
Anthony
post #568 of 580 Old 03-13-2018, 01:24 PM
Vonstallin's Avatar
Images: 16
Attachment 413570
Anthony
ok that sounds perfect.
I think I will just buy another ECU to keep it simple.
post #569 of 580 Old 03-13-2018, 05:18 PM
mpp12's Avatar
buy the extension cable, and a new ECU and be done with it
mpp12 is offline
post #570 of 580 Old 03-14-2018, 10:26 AM Thread Starter
He would need the full harness.
The 2011-2015 uses a Type 3 main and a Type 3a extension which gives you a Type 3a cable set.
The 2016+ uses a Type 13 main and a Type 13a extension which gives you a Type 13a cable set.
The Type 3a extension (for the 2011-2015) is not compatible with the Type 13 main harness (for the 2016) - if they were it'd be sold as such under a different name like Type 3c cable set.
If people are confused about what harnesses are used on what bikes or what bikes require what harnesses there are three ways to check:
1) In the software as shown a few posts back
2) https://www.woolichracing.com/modelharnesses.aspx - Lets you select a model and will show you the appropriate harness
3) https://www.woolichracing.com/harnessmodel.aspx - Lets you select a harness and then shows you the compatible models
