Gen 5: 2016 -> Woolich ETV? - Kawasaki ZX-10R.net
 2Likes
post #1 of 54 Old 12-20-2016, 07:26 PM Thread Starter
Woolich ETV?
Can one change all cells to 100.0 in every gear and all TPS? Wouldn't that make 1 to 1 throttle to throttle blades?
cwrzx is offline
post #2 of 54 Old 12-21-2016, 07:20 AM
turtle1000's Avatar
Pretty sure the bike will run like trash if it runs at all. But I'm no tuner so....
More cowbell
turtle1000 is offline
post #3 of 54 Old 12-21-2016, 07:25 AM
SkyDork's Avatar
Try it and report back the findings.
FI-saki likes this.
#WordCrimes
SkyDork is online now
post #4 of 54 Old 01-07-2017, 04:55 PM
Wouldn't this just make the TPS read as wide open regardless of input?
Fantastic likes this.
Justin33 is offline
post #5 of 54 Old 01-07-2017, 05:59 PM
chiffeee's Avatar
ETV map is the ratio from throttle input to the output. if 100% the ratio is 1:1. TPS is a sensor that reads the position of throttle blade. I haven't try put everything at 100% but by theory, it should work, meaning making 1:1 ratio from throttle input to output. because the throttle input is not 90 degree it would make it hard to control the bike. in another hand, the software may have failsafe which would put the ECU in limp mode if that happens.
chiffeee is offline
post #6 of 54 Old 01-07-2017, 07:35 PM
im constantly playing with the ETVs. The bike will run perfectly fine. Its comparable to removing them. For example.... notice how neutral has much more aggressive ETV tables compared to the "in gear" tables.
If you have the software.... experiment. Thats what ive been doing. I HATE the factory ETV tables. I personally think the bike has terrible manners. You have to give it a fair amount of throttle in the lower rpm/tps to get the bike to move. Then it just "turns on" around 4k and starts going on its own. So far... thats the ETV tables. Also... alot of the twitchy throttle comes from the secondaries being too open at low tps. Ive reduced the angle of them quite a bit for smoother on/off throttle. And opened them up more from 5-30% TPS so it doesnt seem so lazy.
Ejrzx10 is offline
post #7 of 54 Old 01-08-2017, 12:55 AM
michael4012's Avatar
Its all very well adjusting them at will to better refine various parts of response using the butt dyno, but without adjusting your fuel map to suit all your doing is either restricting air flow to richin the fuel ratio or increasing air flow to lean out the fuel ratio, please be careful.
[SIGPIC][/SIGPIC]192MPH stock engined 2008
michael4012 is offline
post #8 of 54 Old 01-08-2017, 02:48 AM
Maniac_ZX10R's Avatar
The Gen 5 doesn't have sondary throttle blades. Don't know what you're adjusting.
Would be quite interesting what happens when you make the map 1:1.
Its the same reading about secondaries, ones say you should not keep it open by map all the time. This could result in a poor airflow. Others delete them completly and say the bikes are running great.
Sometimes it is confusing...
Maniac_ZX10R is offline
post #9 of 54 Old 01-08-2017, 02:58 AM
Another thing is does it allow numbers over 100. If so we would be able to make an electronic short throw throttle?
post #10 of 54 Old 01-08-2017, 06:57 AM Thread Starter
Dyno'd it last week and changed ETV to 100% every where but =<10% TPS. When you watch TPS while on the dyno, you see how much of a delay there is in getting to WOT. I did take it for a short ride but it was too cold for a long ride. It did feel more responsive but I also put a full Akra exhaust on and tuned it. When it gets warmer I'll be able find out how much better it is.
cwrzx is offline
