Gen 5: 2016 -> wheel wobble - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By ddipaola
  • 1 Post By mpp12
  • 1 Post By belkins
post #1 of 10 Old 04-22-2018, 06:32 PM Thread Starter
Alexander Leguizamon's Avatar
wheel wobble
now i know i cant be the only one who has had this problem.... my gen 5 with stock tire and stock ohlins it feels like that crappy ohlins doesnt ever get the job done....suggestions?
Alexander Leguizamon is offline
post #2 of 10 Old 04-23-2018, 08:51 AM
My suggestion is clearly explain your problem to get people's advice and troubleshooting.
The Prophet is offline
post #3 of 10 Old 04-23-2018, 09:47 AM
ddipaola's Avatar
I assume you're talking about the damper... yes the damper is straight up garbage. I get wobble all the time, even with the ABS (or wheelie control) on higher settings. This creates a lot of issues when coming out of corners at punching it. The damper does the job of preventing you from tank slapping to oblivion but my CBR1000RR had all around better damping than this "Ohlins" knock off. I would review this video on how to remove the OEM damper valve. This will prevent throwing any codes. Hide the valve in the bike somewhere, and then install a TOBY racing damper for like $530. Or, as another person recommended to me, purchase an older 2015 damper and have it rebuilt to race spec. I'm sure there's a thread somewhere with a guy on here who can rebuild the older damper for you. $530 for a damper sounds pretty steep but you could easily resell it for $300+ (in like new condition) in a couple years if you ever sell the bike.
ddipaola is offline
post #4 of 10 Old 04-23-2018, 10:22 AM
mpp12's Avatar
you can revalve any ohlins old gen damper for 110 usd or get a fixed needle (a guy here sells it) and be done with it...
whooble has to do with geometry also...
ddipaola likes this.
mpp12 is online now
post #5 of 10 Old 04-23-2018, 10:22 AM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
Find a stock "ohlins" damper from a 06-10 model and have it revalved. You will be into the whole thing for $175 or less. Unhook the stock 16+ damper, tuck the harness under the top tank cover, zip tie or tape it down also. Install the revalved damper. Problem solved. Or spend $450+ on a new Ohlins damper. Also, those Chinese knock off dampers are actually not bad at all. If you can find one that will fit the stock brackets.
https://www.ebay.com/itm/06-07-2006-...hau72L&vxp=mtr
https://www.ebay.com/itm/For-KAWASAK...FaMNR1&vxp=mtr
Because wheelie!!!
16' ZX10R - 08' Hypermotard 1100s
14' Ducati Monster 1200S - SOLD
13' RSV4-R - SOLD
My ZX10R's 11' - 08' - 07' - 05' - 04' - ALL SOLD
Miss my Black 04' the most!
Never enough money, never enough time!
trackaddict is offline
post #6 of 10 Old 04-23-2018, 12:26 PM
belkins's Avatar
not sure if they have the ohlins race scu for gen 5 but after installing it on my gen 4 i've had no issues with the ohlins electronic damper.
trackaddict likes this.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #7 of 10 Old 04-23-2018, 01:09 PM
Images: 51
They do have it. I "think" it's the same module 11-18. I opted for old school. I bet the price break is close either way.
Because wheelie!!!
13' RSV4-R - SOLD
post #8 of 10 Old 04-25-2018, 08:17 AM Thread Starter
i was actually thinking about doing the race scu since i work for a powersports i do get it on discount, just wasnt to sure if it would actually get the job done.... im usually pretty good tech and mechanics but thats where i draw my blank with the damper
post #9 of 10 Old 04-26-2018, 08:07 PM
The Pace
scout's Avatar
What conditions and what exactly is going on.
scout is offline
post #10 of 10 Old 05-24-2018, 05:10 PM Thread Starter
shitty road conditions
