Gen 4: 2011-2015 Turn signal issue. - Kawasaki ZX-10R.net
post #1 of 9 Old 05-14-2017, 04:01 PM Thread Starter
Post Whore
Older Guy's Avatar
Turn signal issue.
See if you can figure this one out.
My turn signals work fine when I start out and after an hour ride.
When I I go to end my ride and get gas, they don't work.
When I pull into the garage, they don't work.
After the bike cools off, they work fine...
Suggestions?
Older Guy is offline
post #2 of 9 Old 05-14-2017, 06:15 PM
The Pace
scout's Avatar
You wash your bike...as in using the hose.
scout is offline
post #3 of 9 Old 05-14-2017, 07:18 PM Thread Starter
Post Whore
Older Guy's Avatar
Never do...
post #4 of 9 Old 05-14-2017, 08:33 PM
bidwell427's Avatar
They do not light up at all or just don't blink? If the latter it may be the flasher.
bidwell427 is offline
post #5 of 9 Old 05-14-2017, 08:50 PM Thread Starter
Post Whore
Older Guy's Avatar
once it gets warm, nothing happens...dead...
post #6 of 9 Old 05-14-2017, 10:00 PM
G37Sam's Avatar
Could be your blinker fluid running too hot haha
G37Sam is offline
post #7 of 9 Old 05-15-2017, 04:57 AM
bidwell427's Avatar
That's damn strange, I would still try changing the flasher. Its the only thing in the electrical chain that could act up, the rest is just hard wiring and a switch.
post #8 of 9 Old 05-15-2017, 04:59 PM
Porschenut's Avatar
I 2nd the flasher relay if you're using aftermarket LED tail lights. Mine went wonky and it was the relay. A buddy's relay also just gave up the ghost even though it had very little use.
At least it's a cheap fix!
Porschenut is offline
post #9 of 9 Old 12-09-2017, 06:53 PM Thread Starter
Post Whore
Older Guy's Avatar
YUP..put in the stock flasher and it worked fine, but fast due to LED's. I bought a relay flash device from Amazon and it worked fine until I hit the road then it blinked faster at higher engine speeds. The TST unit I replaced worked fine for 6 years so I assume it just went bad and I should just get another one of those....I'm calling TST Monday.
