Switched 12V source - Kawasaki ZX-10R.net
 3Likes
  • 2 Post By Doppler
  • 1 Post By SkyDork
post #1 of 4 Old 05-14-2018, 02:02 AM Thread Starter
Switched 12V source
Hi all,
Iím looking for some pointers on where/how to locate a switched 12V source on my Ď13 10R. I run a Battery Tender USB converter to charge my GoPro, and itís getting old having to unplug it every time I park the bike overnight. Iím pretty sure Iím missing something easy since I havenít seen any posts about this, so hopefully somebody can point me in the right direction. Thanks in advance!
THNX SVT is offline
post #2 of 4 Old 05-14-2018, 05:18 AM
Doppler's Avatar
Use a relay and switch it from something like the rear brake switch power or registration plate light.
SkyDork and THNX SVT like this.
-Woolich/Race Tools/Log Box V3|-Graves Titanium/Carbon cat eliminator|-Ohlins Mechatronic|+2 rear|More stuff + stone chips & bugs
Doppler is offline
post #3 of 4 Old 05-14-2018, 09:26 AM
SkyDork's Avatar
Hmmm. I'm confused, as usual. A switched power source would require you to leave the ignition in the "on" position to charge your camera. Not something you would want to do for long periods of time.
So what you really mean is, that you want a switched power source to only power the camera while the bike is on and let it run off battery power otherwise. Gotcha. You should do as Doppler said and pick up the switched taillight signal to activate a relay that you wire in to for your USB connector.
THNX SVT likes this.
#WordCrimes
SkyDork is offline
post #4 of 4 Old 05-15-2018, 02:01 AM Thread Starter
Exactly. Switched so itíll only charge/power the GoPro when the key is on. Itís not so much the GoPro Iím worried about since I donít leave it on the bike when itís parked, but I donít want the USB adapter draining the battery.
Thatís a great idea on the relay and should be simple enough to wire up. Thanks guys!
THNX SVT is offline
