Gen 1: 2004-2005 Swingarm install help - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By davyboy39
post #1 of 4 Old 11-11-2017, 01:14 PM Thread Starter
davyboy39's Avatar
I'm trying to reinstall my swingarm (05 zx10r) and I'm having a problem with getting pivot shaft properly tightened. I'm following the manual instructions as follows:
1. Install the swingarm and insert the pivot shaft. Tighten the pivot adjusting collar to 14 ft-lb.
2. Tighten pivot adjusting collar locknut to 72 ft-lb.
At this point, the swingarm is moving freely up & down.
3. Then I tighten the pivot shaft nut to 81 ft-lb.
Now the swingarm is extremely tight and takes a lot of effort to move up and down. I've taken it apart and put it back together 3 times now. What am I missing? Thanks in advance.
2005 Magma Red ZX10R, Brock’s shortmeg full-system, Dynojet pc3 with Brock’s map, Hellsrazor Servo Eliminator, Block-offs, Cometic thin head gasket (.45mm), Engine Ice Coolant, Gen-3 race cam, Dano’s TRE, BMC race filter, Factory Pro velocity stacks, Cycle Concepts Drag Pak clutch kit, Gold shorty levers, LSL handlebar kit, Drive Systems X2 Ultra-Lightweight 520 sprockets (-1, +2), EK ZZZ 520 Gold chain, Dunlop Q3s, RB Batteries lithium battery (1.4lbs), 1/4 turn keyless gas cap
davyboy39 is offline
post #2 of 4 Old 11-11-2017, 03:18 PM Thread Starter
davyboy39's Avatar
Nevermind. I figured it out. I was missing my left side collar spacer.
Otto Man likes this.
post #3 of 4 Old 11-11-2017, 07:51 PM
Victors's Avatar
Did you install the collar spacer?
2013 10R
2007 650R
2016 10R
Victors is offline
post #4 of 4 Old 11-12-2017, 08:18 PM
blink.'s Avatar
Did anyone mention the collar spacer?
blink. is offline
