Gen 4: 2011-2015 Suspension Setup - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 19 Old 03-15-2016, 08:10 AM
Always On Mod
Animal11's Avatar
Originally Posted by Crescent1101 View Post
What do you mean under clevis? Can't you adjust ride height on the ohlins?
Between the clevis and the frame to increase the ride height. Yes I could just increase the length of the ohlins shock, but I'm lazy and the shims were already installed
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #12 of 19 Old 03-15-2016, 09:49 AM
LDH
LDH's Avatar
Assuming you have the Ohlins Shock custom valved for the Kyle Racing Link then set-up with the Kyle 5% Link is very simple. You shorten the Ohlins shock as short as it will go and install a 6mm shim at the shock mount. It works! In fact, it works so well that it basically takes all the guesswork out of the rear of the bike and all you really need to do is fine tune the front geometry to your liking.
My Current Set-Up
REAR:
Kyle Racing 5% Linear Race Link
6mm Shim
Ohlins TTX-GP Shock short as possible, (C37-R5 Valving at 13 clicks on Compression and 14 clicks Rebound which is specifically 3 less clicks at WSIR than I run anywhere else)
Axle Middle to Back is the prescribed setting for the really fast Pro riders, but I find running it more towards the middle works for me
27mm Rider Sag
FRONT:
Stock Triple Clamp
Ohlins FGRT NIX Forks 4mm above the top clamp to top of fork tube (11 clicks Comp, 11 clicks Reb)
Oil Height 185mm
35mm Rider Sag (lighter springs with more preload seem to be preferred by most over heavier springs and less preload to attain the same sag numbers)
CanyonCarver and serialize like this.
LDH is online now
post #13 of 19 Old 03-15-2016, 10:18 AM Thread Starter
Crescent1101's Avatar
My Current Set-Up
REAR:
6mm Shim
27mm Rider Sag
FRONT:
Stock Triple Clamp
Oil Height 185mm
Thanks man! I don't think my shock has the recall done. It was rebuilt by Precision Tuning but I don't think the recall was addressed. I havent done the valving for the Link yet. I was wondering if I could get that done during my recall?
2013 ZX10R
Ohlin TTX rear shock, Brembo 19X20, Rifleman throttle insert, Graves Slip-on, Yoshimura engine and frame sliders, Woolich USB, Motoholders Carbon Fiber Intake and stay, Woodcraft clip-ons, -1, +2 gearing, EK 520 chain, Spielgler brake lines, Vortex rear sets/GP Shift, Vortex gas cap, CRG shorty levers, BMC race filter, Driven Block-off plates etc
2008 ZX10R- SOLD
Crescent1101 is offline
post #14 of 19 Old 03-15-2016, 11:00 AM
serialize's Avatar
That's when I got mine done.
Has to do with seating the locking nut for the mechanical stop I believe but ask Precision if they did it they might have.
Like bikes ......... Like Kawasaki ........
1996 ZX6R, 2003 ZX636, 2009 ZX6R, 2011 ZX10R
2006 R6-R, 2007 R6-R, 2010 FZ1
2005 CRF250R, 2011 KTM 350sxf
serialize is offline
post #15 of 19 Old 04-06-2016, 12:51 AM
Sven#66's Avatar
315mm shock length I know some like 316 for better turn in.
Front forks pulled through to 13mm
In the class is Race we have to have standard forks and shocks.
Spring on shock 120 and standard springs in forks.
Sven#66 is offline
post #16 of 19 Old 04-06-2016, 01:08 AM
Sven#66's Avatar
Pre Load on shock 11-13mm
Air gap in Forks 130
Sven#66 is offline
post #17 of 19 Old 09-19-2017, 02:56 PM
My Current Set-Up
REAR:
6mm Shim
27mm Rider Sag
FRONT:
Stock Triple Clamp
Oil Height 185mm
Are you still using these same setting for your rear shock?
desmoninja is offline
post #18 of 19 Old 09-19-2017, 02:59 PM
LDH
LDH's Avatar
The geometry is the exact same, but the Rebound clicks may be a 1 or 2 off from that.
LDH is online now
post #19 of 19 Old 09-19-2017, 03:12 PM
Thanks! I have the Kyle racing black link and C37-R5 valving so I'll give it a try. With any luck maybe I can get another track day out of my rear tire.
