Gen 5: 2016 -> Steering Damper Solution - Kawasaki ZX-10R.net
 29Likes
post #1 of 53 Old 08-30-2016, 12:59 PM Thread Starter
FI-saki's Avatar
I'm started to really get tired of stock electronic steering damper and all those unpredictable tank slappers what happens pretty often.
Is there any solution available to improve electronic damper or should I return manual dampers I used and liked before Gen. 5?
What is needed to disconnect electronic damper and install manual damper without any Fi light and/or other issues?
FI-saki is offline
post #2 of 53 Old 08-30-2016, 01:22 PM
SkyDork's Avatar
Been discussed ad nauseam.
First, if you had a tank slapper, you'd have crashed. If you're getting headshake, you have a set up/geometry problem. Especially if it's re-occurring frequently.
You can install the Ohlins race SCU to change the characteristics of the ESD. Or you can remove the ESD and install a manual one. You'll need to retain the ESD motor to keep the caution light from coming on. There's a how-to thread on doing that.
mr_honez, SDsting, LDH and 2 others like this.
#WordCrimes
SkyDork is offline
post #3 of 53 Old 08-30-2016, 01:29 PM
After I got my ECU flashed i had some issues of head shake. But I quickly realized I was holding the bars too tight. Maybe that will help you OP.
SkyDork, mr_honez and FI-saki like this.
2016 Kawasaki ZX10R KRT ABS
2016 Suzuki GSX-S 1000 ABS
obijack is offline
post #4 of 53 Old 08-30-2016, 01:53 PM
Judge Dredd Mod
mr_honez's Avatar
to both of those.
Headshake issues are most likely caused by set up issues and/or rider input. A properly set up motorcycle will rarely experience headshakes when ridden correctly.
BURNOUT.....
mr_honez is offline
post #5 of 53 Old 08-30-2016, 03:07 PM
tdh
tdh's Avatar
I have a 2014 with the ESD and the Ohlins race SCU. I also have a 2016 that came with the same ESD that I took apart and removed the servo which I tucked under the tank, then installed a revalved (by Velocity Calibrations) manual damper on it. I like both options. Here's a video I made on how to remove the servo from the ESD:
obijack and FI-saki like this.
tdh is offline
post #6 of 53 Old 08-30-2016, 04:10 PM
belkins's Avatar
I just recently got the ohlins scu for my 2013 and i must say it helped a lot! the gen5 uses the same ohlins scu as the gen4...
give mike a pm or call @ridersdiscount is his forums name or website is www.ridersdiscount.com he gave me a great deal on mine.
ridersdiscount and FI-saki like this.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #7 of 53 Old 08-30-2016, 06:41 PM
The Pace
scout's Avatar
what are you doing to produce a 'tank slapper?' and what past bike with a manual damper.
scout is offline
post #8 of 53 Old 08-30-2016, 10:14 PM Thread Starter
FI-saki's Avatar
Okay. I redefine; I'm getting frequent head-shakes. Often while acceleration and due to road surface inequalities. Sure, there are occasionally rider error involved but I think that's reason aids are partly made for? Yeah, being heavy on bars! I feel I just can barely touch bars while acceleration.
I'm sure stock electronic damper is not optimal for road racing (bounces, jumps, etc.) as I used before manual damper and it performed much better.
FI-saki is offline
post #9 of 53 Old 08-30-2016, 10:18 PM
The Pace
scout's Avatar
Get Code's Twist Wrist book from amazon. The section on pivot points you must focus upon but the entire work is fundamental for riding. Foundational as in Code lays out the concepts and after a few years most dial in and get creative. So much going on and Code lays it out nicely.
scout is offline
post #10 of 53 Old 08-30-2016, 10:21 PM Thread Starter
FI-saki's Avatar
I'm getting frequent head-shakes, while acceleration and due to road surface inequalities. I Feel like I can't even touch bars at all.
R6
FI-saki is offline
