Gen 4: 2011-2015 sprockets and chain - Kawasaki ZX-10R.net
 13Likes
post #1 of 20 Old 04-22-2018, 05:56 PM Thread Starter
gonzosport9's Avatar
sprockets and chain
Good evening everyone. i was out riding last night and unfortunately i broke a good portion of my teeth in my sprocket and it's time to order a new one. From the previous owner its a 520 set with rk chain, rear sprocket was renthal and my front sprocket was driven. not trying to piece out like that and looking to get one set if possible. i read some good things about driven but wanted to see if anyone has any other recommendations they think i should go with. Thanks in advance for all advise really appreciate it!
gonzosport9 is offline
post #2 of 20 Old 04-22-2018, 06:55 PM
LDH
LDH's Avatar
I've been using and selling the Drive Systems steel stuff with DID ZVM-X chain for about 4 seasons now. They last forever with minimal maintenance. In fact I kinda wish they weren't so good as I sell a lot less sprocket kits now that everyone has gone away from Alloy sprockets we all used to use to these Steel rears.
gonzosport9 likes this.
LDH is offline
post #3 of 20 Old 04-23-2018, 07:26 AM Thread Starter
How much would a set cost me??
post #4 of 20 Old 04-23-2018, 07:56 AM
ddipaola's Avatar
Now is a good time to just start from scratch. Screw the 520 chain BS and stick with OEM pitches. Also, avoid driven for your drive-train. I know they're products are widely used and backed but stick with a company that specializes in chain/sprocket manufacturing like Vortex, DID, Renthal, JT, or RK. Try a -2/-4, 525 pitch set-up. You're dropping weight and you're not screwing with any power (you'll get a +2% torque gain and -2% top speed). If you're having a hard time finding sprockets with that tooth count try this: https://www.motosport.com/motorcycle..._position=Rear
Only con to dropping weight like this though is sprocket life. You're looking at 90% life vs OEM 525 gearing, but probably 100+% the life of your 520 set-up.
ddipaola is offline
post #5 of 20 Old 04-23-2018, 08:38 AM
mpp12's Avatar
buy a EK 3D chain, buy a stock back, plenti in ebay like new and weight the same as a brand steel, and buy a renthal or driven front -1.
and forget about this.
mpp12 is offline
post #6 of 20 Old 04-23-2018, 08:42 AM
Agreed, I even started using Stainless steel rear sprockets on my Yz450 motocross bike. They are cut out big time so the weight is less than a conventional steel sprocket. They last forever. The only drawback is that they last so long you forget that you should replace the chain before it breaks or wears out.
gonzosport9 and ddipaola like this.
The Prophet is offline
post #7 of 20 Old 04-23-2018, 12:11 PM
belkins's Avatar
been happy with my DID Chain 520 setup with driven rear and front sprocket -1 +2.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #8 of 20 Old 04-23-2018, 01:41 PM
mpp12's Avatar
-1 +2 = no top end.... no bueno
gen4 is -1F
gen 5 is +1R
mpp12 is offline
post #9 of 20 Old 04-23-2018, 02:40 PM
LDH
LDH's Avatar
gen4 is -1F
gen 5 is +1R
Come on bro...
1. The bike as delivered is limited to 186mph
2. The bike as delivered barely has enough hp to pull redline in 6th gear and you aren't going to set any top speed records
3. Who in the hell is really riding around at redline in 6th gear at 186+mph?
CanyonCarver and belkins like this.
LDH is offline
post #10 of 20 Old 04-23-2018, 03:02 PM
mpp12's Avatar
LDH,
I really respect your point of view...makes you sense...
1 - A flash and the bike is not limited.
2- correct, the bike barely gets to near the limiter in 6th even with flash... mine has like 193hp and -1F gets 13700rpm in the data logger when riding here in 6th gear.
3- Bring you bike to Dominican Republic and get ready to ride really fast.... more than a couple of bikes here blown up in the way from Sto Dgo to Punta Cana... long straights and 130+mph curves. for 50kms.
you need top speed not to get records, you need top speed because when you ride with guys that can ride fast you need all you can get, and my experience is, you get 2 short and the bike just revs and revs and dont move forward (hope I make sense), 2 long and the bike does not get to the sweet spot, you need the bike short so it can move the bike when winds are not helping and when the wind favors, the bike the power does not drop...
-1F and +2 on the back you lose on a gen4 like 6mph
the shortest for flash stock power would be -1+1.
michael4012 likes this.
mpp12 is offline
