Gen 5: 2016 -> Sprocket change or OEM? - Page 5 - Kawasaki ZX-10R.net
 8Likes
post #41 of 45 Old 01-13-2017, 08:13 PM
Otto Man's Avatar
Send a message via AIM to Otto Man
At places like Road Atlanta, Road America, VIR, NJMP? Yeah, not too far off from stock. Nothing night and day like -1/+3 stuff.
Otto Man is offline
post #42 of 45 Old 01-14-2017, 03:18 AM
dricked's Avatar
Our tracks require it, not because I'm slow and can't carry corner speed but because the track is slow and if you run stock gearing you'll be using 1st-3rd gear and maybe touching 4th. You'll get left behind out of corners because you'll be at 4,000rpm in 2nd. Same as I can't run the same shock/fork springs at every track. If you want to be competitive with the top guys you need to change things and make the bike work. We had a guy run +1f (18) and not sure the rear, at Mosport last year. He lost to Corti by milliseconds.
I'll say it again, every track is different and why I carry 3 fronts, 5 rears, and two chains.
On the street who's carrying huge corner speed anyway?
dricked is offline
post #43 of 45 Old 02-21-2017, 04:37 PM
KRTone's Avatar
Originally Posted by SkyDork View Post
Then there are guys like me who prefer +2 rear only so the change is not too aggressive and it shortens the wheelbase to help with turn-in slightly. Plus the rear sprocket is much easier to change. This is essentially the same as going -1F, but with the advantages I just mention.
Just so Im clear, you can go +2 and keep the stock chain, or would you need to get an aftermarket 525 or go down to 520 chain?
KRTone is offline
post #44 of 45 Old 02-22-2017, 05:23 PM
sdiver68's Avatar
Usually you can go +2 and keep the stock 525 chain, as long as you have enough room to move the axle forward. Safer to go -1 Front for about the same effect as +2R...and IDK why people think it's so hard to change? A heavy duty impact wrench is all you need.
If you switch to a 520 chain, then you'll need both F and R sprockets.
To be honest, -1F and Rifleman was plenty to really wake my bike up and effectively use 3rd gear on back roads for a street bike. I'm pretty skeptical of racers who feel they need all those gearing options on 1000.
Jlefevre1122 likes this.
Thank you to my racing sponsors Riders Discount and Alpha1 Vinylworks
sdiver68 is offline
post #45 of 45 Old 03-05-2017, 01:50 PM
G37Sam's Avatar
Glad I'm not the only one who thought the Gen 5 gearing is way too long, I went with a -1/+1 Renthal Sprockets, they should be here any day now, will install them and report back. Keeping the OEM chain for now as it barely has 600 km's on it.
G37Sam is offline
